1 Reply Latest reply on May 17, 2008 5:42 AM by slaingod
    Vector Graphics Re-Sizing
      Hi There,
      I'm relatively new to Flex but I've googled around and I can't come across an answer so I'm hoping you can help. I've come across a bit of a problem. I've defined a region using a set of co-ordinates and the graphics class method lineTo(x, y). That all works fine and achieves exactly what is needed, however, now it's possible that it may have to be re-sized, i've tried re-sizing the components to which this region has been added with no such luck which I assume is because it's still manually plotting out the co-ordinates which means I can only assume that the co-ordinates have to be changed to match the scaling of the re-sizing but unfortunately, I'm no maths genius and working out a formula to achieve that is near impossible (for me anyway...).
      Is there something I'm missing?
      Thanks in advance.
