I have deployed the cfusion.ear file that got created during the ColdFusion 2016 install. I'm trying to get to ColdFusion admin and I'm receiving the exception below. Has anyone ran into this. I have tried running the hotfix, but still get same error.
Operating System: Windows 64bit
[2/5/18 9:37:11:675 CST] 000000a0 webapp E com.ibm.ws.webcontainer.webapp.WebApp logServletError SRVE0293E: [Servlet Error]-[CfmServlet]: javax.servlet.ServletException: ROOT CAUSE:
coldfusion.server.ServiceFactory$ServiceNotAvailableException: The Monitoring service is not available.
at coldfusion.server.ServiceFactory.getMonitoringService(ServiceFactory.java:223)
at coldfusion.CfmServlet.service(CfmServlet.java:199)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1233)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:782)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:481)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:136)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:97)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:195)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:91)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:967)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1107)
at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:3980)
at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:304)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:1016)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(HttpInboundLink.java:287)
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.sendToDiscriminators(NewConnectionInitialReadCallback.java:214)
at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.complete(NewConnectionInitialReadCallback.java:113)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70)
May I know the IBM JDK which you are using with WAS 8.5.5?
Priyank Shrivastava
Hello Priyank,
Thank you for your response. Here is my java version:
Java version = 1.8.0, Java Runtime Version = pwa6480sr3fp20ifx-20161110_01
(SR3 FP20IV90630IV90578), Java Compiler = j9jit28, Java VM name = IBM J9
VM
Thank you,
Matt
On Tue, Feb 6, 2018 at 9:21 AM, priyanks97293812 <forums_noreply@adobe.com>
Hi Matt,
Have you recently updated the Java in your WAS server?
Priyank Shrivastava
Hello,
This is a brand new install.
Thank you,
On Wed, Feb 7, 2018 at 7:05 AM, priyanks97293812 <forums_noreply@adobe.com>
@priyanks97293812 did you get this resolved? I am having the same issue
Patrick, what similarities do you share with the opportunity, Matthew? Are you also on websphere? Also getting this on initial launch of the cf admin?
If not a new install, then what changesd before things failed? Have you perhaps recently applied a cf or jvm update? Had a recent crash?
Any of the above could be clues to your resolution
Yes,I have the exact same issue. New install on Websphere 8.5.5. Trying to access the admin.
Hi Patrick,
I have deployed WAS8.5.5.13 with Java 8 and it worked without any issue. Unfortunately, I never got a chance to work with Matthew.
I received your email, I will be working with you on this.
Priyank
Patrick did you ever resolve this, perhaps with the kind offer of direct help from Priyank of Adobe? I suspect there's a solution but I didn't dig in further since he was prepared to.
Hi Charlie,
I sent an email to Patrick but never heard back from him. Perhaps, he resolved the issue. I deployed ColdFusion 2016 on WAS8.5.5 with Java 7 and WAS 8.5.5.13 with Java 8 and both worked just fine.
I am unable to reproduce the issue in both Windows/Linux environment, so if anyone has an issue with the deployment. They can contact us and we will help.
Priyank Shrivastava
Hi Priyank,
I received a question about this error today. They tried to deploy a WAR file of CF2016U6 using a cluster of 3 VMs with RedHat Enterprise 7.5 and Weblogic 12.1.3 / JDK 1.8.0_162.
When starting the instances they received this error:
####<May 3, 2018 3:07:27 PM CEST> <Error> <HTTP> <xxxx.xxxx.xxx> <xxxxxxx> <[ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> <1525352847467> <BEA-101017> <[ServletContext@1905821284[app:cf_bshop module:cf_bshop path:null spec-version:3.0]] Root cause of ServletException.
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:346)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:25)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79)
at coldfusion.filter.ClickjackingProtectionFilter.doFilter(ClickjackingProtectionFilter.java:75)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3436)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3402)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2285)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2201)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2179)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1572)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:255)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:311)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:263)
Thank you,
Chris
Hi Chris,
Thanks for sharing your query with us.
ColdFusion 2016 J2EE deployment only works on WebLogic 12.2.1 onwards. That is the reason you are getting 'The Monitoring Service not available'. Please try using the WebLogic 12.2.x
I have already asked document team to mention the version, I will check again and update the support matrix.
Priyank
