4 Replies Latest reply on Feb 13, 2018 1:59 AM by meenakshin83966505 Branched from an earlier discussion. Branched to a new discussion.
    How to sign document YOURSELF before sending to recipient??
    hrenkoins2018
      I don't see this option anywhere. How can I prefill a form, sign it, and then email the form to be signed from Adobe Acrobat Pro DC on Windows 10?
        • 1. Re:  How to sign document YOURSELF before sending to recipient??
          meenakshin83966505 Adobe Employee
          Hi Holdenl,
          If you need to sign the document yourself in Adobe Sign account, you can use the Fill & Sign option s show below in the screenshot
          Take help of the steps mentioned here: Adobe Sign - Fill & Sign
          Once you add the signature to the document, you will get an option to "Send a copy" or "Download a copy"
          You can use either of the options.
          On selecting "Send a copy", the document will be sent to the recipient as an attachment from your Adobe Sing account.
          They can download the form and sing it using the Adobe Acrobat DC.
          If you select the "Download a copy", then you can manually send the document from your email account as an attachment.
          Let us know if you have any questions.
          Regards,
          Meenakshi
          2 people found this helpful
          • 2. Re:  How to sign document YOURSELF before sending to recipient??
            hrenkoins2018 Level 1
            This option doesn't work for me.
            Once I sign a document, it becomes uneditable. I want to fill the form I've prepared so that absolutely 0 omissions are made, then sign, then send for a signature. By using the fill and sign method, I can't have a form sent out to be filled out by customers, nor can I use my form for my own use prior to signing.
            • 3. Re:  How to sign document YOURSELF before sending to recipient??
              Also to add, I don't want to use documents.adobe.com to upload everything I used. I want to do everything directly from the app I'm paying for.
              • 4. Re:  How to sign document YOURSELF before sending to recipient??
                Hi Holdenl,
                I see that you have Adobe Acrobat Pro DC subscription.
                It seems that you are using the Fill & Sign option in Adobe Acrobat DC. Once you sign the PDF using that option in Acrobat DC, then you cannot make any changes to PDF.
                Open PDF that you need to send and select "Send for Signature" tool.
                Then add your email address in the "TO" field and then the other email address to whom you have to send after filling the form.
                Once done, click on next at the bottom. Now add the form fields to the form and assign the form fields to the signer.
                Take help from here Assign form fields to recipients.
                Once done, you will get an option "Sign, then Send" at the bottom right in the blue box.
                Then you can fill the form and once done it will forward to another signer.
                Let us know if you need any help or have any questions.
                Regards,
                Meenakshi
