8 Replies Latest reply on May 19, 2008 8:21 AM by dam85
    Problem about importing class
    dam85
      Hello,
      i have this code.
      <!-- NameProject.mxml -->
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:my="components.*" width="100%" height="100%">
      <mx:Script>
      <![CDATA[
      import lib.User;
      public var u:User = new User();
      trace(u.say("hello world"));
      </mx:Script>
      </mx:Application>
      <!-- /lib/User.as -->
      package lib{
      public class User{
      public function say(s:String):String{
      return s;
      i get this error:
      1120 Access of undefined property
      Why??
      thanks so much
        • 1. Re: Problem about importing class
          peterent Level 2
          You have this statement: trace(u.say("hello world")); but it isn't not inside any function. That may be the problem. I don't know off the top of my head if the error you are getting is a compile-time or runtime error. Which is it?
          • 2. Re: Problem about importing class
            dam85 Level 1
            quote:
            i see this error when i do a 'clear' on my adobe flex builder
            1120 Access of undefined property u.
            • 3. Re: Problem about importing class
              dam85 Level 1
              i wrote the same rows read from adobe flex online manual. :(
              • 4. Re: Problem about importing class
                peterent Level 2
                You have this Script block in your code:
                <mx:Script>
                <![CDATA[
                import lib.User;
                </mx:Script>
                The trace statement is just "floating" in there - it must be in a function. When do you want this trace executed? For example, if you want to display it when the Application dispatches its creationComplete event, then add a creationComplete event handler to the Application tag and then write the function to handle the event in the Script block:
                <mx:Application ... creationComplete="initApp()">
                <mx:Script>
                <![CDATA[
                import lib.User;
                private function initApp() : void {
                </mx:Script>
                Now the trace statement appears in a function so you will not get the error.
                • 5. Re: Problem about importing class
                  dam85 Level 1
                  yes, very good! now works!!!
                  thanks so much.....the last question...
                  but if i create an instance of a class in my main.mxml
                  example:
                  public var s:User = new User();
                  i can write a function, like this
                  public function getMyObj():User{
                  return s;
                  i think this code should works, but how can i call this function (getMyObj()) in other .mxml files?
                  i hate to use the same class instance for every mxml file
                  how could i do?
                  thanks again
                  • 6. Re: Problem about importing class
                    dam85 Level 1
                    ...i have to use.... NOT i "HATE" :)
                    • 7. Re: Problem about importing class
                      peterent Level 2
                      From any class in your application you can do this:
                      import NameProject;
                      var app:NameProject = Application.application as NameProject;
                      var u:User = app.getMyObj();
                      • 8. Re: Problem about importing class
                        dam85 Level 1
                        perfect!!! thanks
