5 Replies Latest reply on Feb 10, 2018 5:10 AM by JJMack
    Rotate tool and liquify don't work
    Bereh
      Hi, guys!
      I have some problems! Even with GPU processor activated, the 'rotate tool' and the 'liquify filter' don't work in Photoshop 2018. I think is not a problem with hardware because all of then are updated. It's important to point that, I don't know why, my Photoshop was working properly for some days since last week, but now the problem is back.
        • 1. Re: Rotate tool and liquify don't work
          Chuck Uebele Adobe Community Professional & MVP
          When issues come up suddenly of things that used to work but suddenly don't. It's often that the preferences need to be reset. I would try that; however, it sounds like you might be having issues with your graphics card. Is it an Intel card? I have had a lot of issues with Intel graphics cards working then not working. PS has a sniffer program that detects if your graphics card is working. if the sniffer doesn't get the proper response back from the card, it will disable things in PS, like the rotate tool.
          • 2. Re: Rotate tool and liquify don't work
            Have you unchecked use Graphic Processor in your Preferences Performance.  Those features require the use of your GPU
            • 3. Re: Rotate tool and liquify don't work
              Bereh Level 1
              Hi, Chuck!
              My computer works with: Intel(R) HD Graphics 5500 + AMD Radeon R7 M260
              Then the settings provided by Photoshop:
              Adobe Photoshop Version: 19.1.0 20180116.r.238 2018/01/16: 1153018  x64
              Number of Launches: 2
              Operating System: Windows 10 64-bit
              Version: 10 or greater 10.0.16299.15
              System architecture: Intel CPU Family:6, Model:13, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
              Physical processor count: 2
              Logical processor count: 4
              Processor speed: 2394 MHz
              Built-in memory: 16298 MB
              Free memory: 4072 MB
              Memory available to Photoshop: 14248 MB
              Memory used by Photoshop: 70 %
              Alias Layers: Disabled.
              Modifier Palette: Enabled.
              Highbeam: Enabled.
              Image tile size: 128K
              Image cache levels: 4
              Font Preview: Medium
              TextComposer: Latin
              Display: 1
              Display Bounds: top=0, left=0, bottom=1080, right=1920
              OpenGL Drawing: Enabled.
              OpenGL Allow Old GPUs: Not Detected.
              OpenGL Drawing Mode: Advanced
              OpenGL Allow Normal Mode: True.
              OpenGL Allow Advanced Mode: True.
              AIFCoreInitialized=1
              AIFOGLInitialized=1
              OGLContextCreated=1
              NumGLGPUs=1
              NumCLGPUs=2
              NumNativeGPUs=0
              glgpu[0].GLVersion="4.1"
              glgpu[0].IsIntegratedGLGPU=0
              glgpu[0].GLMemoryMB=1024
              glgpu[0].GLName="Intel(R) HD Graphics 5500"
              glgpu[0].GLVendor="Intel"
              glgpu[0].GLVendorID=32902
              glgpu[0].GLDriverVersion="20.19.15.4531"
              glgpu[0].GLRectTextureSize=16384
              glgpu[0].GLRenderer="Intel(R) HD Graphics 5500"
              glgpu[0].GLRendererID=5654
              glgpu[0].HasGLNPOTSupport=1
              glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll"
              glgpu[0].GLDriverDate="20160929000000.000000-000"
              glgpu[0].CanCompileProgramGLSL=1
              glgpu[0].GLFrameBufferOK=1
              glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4531"
              glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
              glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
              glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
              glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
              glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
              glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
              glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
              glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
              glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
              glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
              glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
              glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
              glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
              clgpu[0].CLPlatformVersion="2.0 "
              clgpu[0].CLDeviceVersion="2.0 "
              clgpu[0].IsIntegratedCLGPU=1
              clgpu[0].CLMemoryMB=6511
              clgpu[0].CLName="Intel(R) HD Graphics 5500"
              clgpu[0].CLVendor="Intel(R) Corporation"
              clgpu[0].CLVendorID=32902
              clgpu[0].CLDriverVersion="20.19.15.4531"
              clgpu[0].CLBandwidth=1.7237e+10
              clgpu[0].CLCompute=165.692
              clgpu[1].CLPlatformVersion="2.1 AMD-APP (2527.8)"
              clgpu[1].CLDeviceVersion="2.0 AMD-APP (2527.8)"
              clgpu[1].IsIntegratedCLGPU=0
              clgpu[1].CLMemoryMB=2048
              clgpu[1].CLName="Iceland"
              clgpu[1].CLVendor="Advanced Micro Devices, Inc."
              clgpu[1].CLVendorID=4098
              clgpu[1].CLDriverVersion="2527.8"
              clgpu[1].CLBandwidth=1.19638e+10
              clgpu[1].CLCompute=348.5
              License Type: Subscription
              Serial number: 90970807805206507800
              GUIDBucket:
              Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
              Temporary file path: C:\Users\ildem\AppData\Local\Temp\
              Photoshop scratch has async I/O enabled
              Scratch volume(s):
                Startup, 919,5G, 198,9G free
              Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
              Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
              Installed components:
                 A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                 ACE.dll   ACE 2017/11/22-18:28:12   79.589342   79.589342
                 AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                 AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                 AdobeOwl.dll   Adobe Owl   5.2.11
                 AdobePDFL.dll   PDFL 2017/10/31-06:12:59   79.250229   79.250229
                 AdobePIP.dll   Adobe Product Improvement Program   7.4.1.109.46827
                 AdobeSVGAGM.dll   AdobeSVGAGM   79.588619   79.588619
                 AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
                 AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
                 AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
                 adobe_caps.dll   Adobe CAPS   10,0,0,6
                 AGM.dll   AGM 2017/11/22-18:28:12   79.589342   79.589342
                 ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
                 AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                 amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
                 ARE.dll   ARE 2017/11/22-18:28:12   79.589342   79.589342
                 AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                 AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                 Bib.dll   BIB 2017/11/22-18:28:12   79.589342   79.589342
                 BIBUtils.dll   BIBUtils 2017/11/22-18:28:12   79.589342   79.589342
                 boost_date_time.dll   photoshopdva   11.1.0
                 boost_filesystem.dll   photoshopdva   11.1.0
                 boost_signals.dll   photoshopdva   11.1.0
                 boost_system.dll   photoshopdva   11.1.0
                 boost_threads.dll   photoshopdva   11.1.0
                 cg.dll   NVIDIA Cg Runtime   3.0.00007
                 cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                 CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                 CoolType.dll   CoolType 2017/11/22-18:28:12   79.589342   79.589342
                 CRClient.dll   Adobe Crash Reporter Client DLL   1.6.3.0
                 dnssd.dll   Bonjour   3,0,0,2
                 dvaaudiodevice.dll   photoshopdva   11.1.0
                 dvacore.dll   photoshopdva   11.1.0
                 dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                 dvamarshal.dll   photoshopdva   11.1.0
                 dvamediatypes.dll   photoshopdva   11.1.0
                 dvametadata.dll   photoshopdva   11.1.0
                 dvametadataapi.dll   photoshopdva   11.1.0
                 dvametadataui.dll   photoshopdva   11.1.0
                 dvaplayer.dll   photoshopdva   11.1.0
                 dvatransport.dll   photoshopdva   11.1.0
                 dvaui.dll   photoshopdva   11.1.0
                 dvaunittesting.dll   photoshopdva   11.1.0
                 dynamiclink.dll   photoshopdva   11.1.0
                 ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1150526   81.1150526
                 icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                 icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                 icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                 igestep30.dll   IGES Reader   9.3.0.113
                 imslib.dll   IMSLib DLL   10.0.0.22
                 JP2KLib.dll   JP2KLib 2017/10/31-01:22:04   79.268591   79.268591
                 libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                 libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                 libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                 LogSession.dll   LogSession   7.4.1.109.46827
                 mediacoreif.dll   photoshopdva   11.1.0
                 MPS.dll   MPS 2017/10/31-01:22:04   79.588396   79.588396
                 pdfsettings.dll   Adobe PDFSettings   1.04
                 Photoshop.dll   Adobe Photoshop CC 2018   19.1.0
                 Plugin.dll   Adobe Photoshop CC 2018   19.1.0
                 PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.5.0
                 PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.5.0.87
                 PSArt.dll   Adobe Photoshop CC 2018   19.1.0
                 PSCloud.dll                                                   1.0.0.1
                 PSViews.dll   Adobe Photoshop CC 2018   19.1.0
                 SCCore.dll   ScCore 2017/08/31-12:13:14   81.1150526   81.1150526
                 SVGRE.dll   SVGRE   79.586793   79.586793
                 svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                 tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                 tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                 TfFontMgr.dll   FontMgr   9.3.0.113
                 TfKernel.dll   Kernel   9.3.0.113
                 TFKGEOM.dll   Kernel Geom   9.3.0.113
                 TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                 updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                 VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                 VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                 WinRTSupport.dll   Adobe Photoshop Windows RT Support   19.0.0.0
                 WRServices.dll   WRServices Thu June 21 2017 12:26:24   Build 0.22473   0.22473
                 wu3d.dll   U3D Writer   9.3.0.113
              Required plug-ins:
                 3D Studio 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Accented Edges 19.1.0 - from the file “Filter Gallery.8bf”
                 Adaptive Wide Angle 19.1.0 - from the file “Adaptive Wide Angle.8bf”
                 Angled Strokes 19.1.0 - from the file “Filter Gallery.8bf”
                 Average 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Average.8bf”
                 Bas Relief 19.1.0 - from the file “Filter Gallery.8bf”
                 BMP 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Camera Raw 10.1 - from the file “Camera Raw.8bi”
                 Camera Raw Filter 10.1 - from the file “Camera Raw.8bi”
                 Chalk && Charcoal 19.1.0 - from the file “Filter Gallery.8bf”
                 Chrome 19.1.0 - from the file “Filter Gallery.8bf”
                 Cineon 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Cineon.8bi”
                 Clouds 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Clouds.8bf”
                 Collada 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Color Halftone 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Colored Pencil 19.1.0 - from the file “Filter Gallery.8bf”
                 CompuServe GIF 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Conté Crayon 19.1.0 - from the file “Filter Gallery.8bf”
                 Craquelure 19.1.0 - from the file “Filter Gallery.8bf”
                 Crop and Straighten Photos 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “CropPhotosAuto.8li”
                 Crop and Straighten Photos Filter 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Crosshatch 19.1.0 - from the file “Filter Gallery.8bf”
                 Crystallize 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Cutout 19.1.0 - from the file “Filter Gallery.8bf”
                 Dark Strokes 19.1.0 - from the file “Filter Gallery.8bf”
                 De-Interlace 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Dicom 19.1.0 - from the file “Dicom.8bi”
                 Difference Clouds 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Clouds.8bf”
                 Diffuse Glow 19.1.0 - from the file “Filter Gallery.8bf”
                 Displace 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Dry Brush 19.1.0 - from the file “Filter Gallery.8bf”
                 Eazel Acquire 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “EazelAcquire.8ba”
                 Entropy 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Export Color Lookup Tables 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Export3DLUT.8be”
                 Extrude 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 FastCore Routines 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “FastCore.8bx”
                 Fibers 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Film Grain 19.1.0 - from the file “Filter Gallery.8bf”
                 Filter Gallery 19.1.0 - from the file “Filter Gallery.8bf”
                 Flash 3D 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Fresco 19.1.0 - from the file “Filter Gallery.8bf”
                 Glass 19.1.0 - from the file “Filter Gallery.8bf”
                 Glowing Edges 19.1.0 - from the file “Filter Gallery.8bf”
                 Google Earth 4 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Graphic Pen 19.1.0 - from the file “Filter Gallery.8bf”
                 Halftone Pattern 19.1.0 - from the file “Filter Gallery.8bf”
                 Halide Bottlenecks 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “HalideBottlenecks.8bx”
                 HDRMergeUI 19.1.0 - from the file “HDRMergeUI.8bf”
                 HSB/HSL 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 IFF Format 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 IGES 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Ink Outlines 19.1.0 - from the file “Filter Gallery.8bf”
                 JPEG 2000 19.1.0 - from the file “JPEG2000.8bi”
                 Kurtosis 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Lens Blur 19.1.0 - from the file “Lens Blur.8bf”
                 Lens Correction 19.1.0 - from the file “Lens Correction.8bf”
                 Lens Flare 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Liquify 19.1.0 - from the file “Liquify.8bf”
                 Matlab Operation 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “ChannelPort.8bf”
                 Maximum 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Mean 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Measurement Core 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “MeasurementCore.8me”
                 Median 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Mezzotint 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Minimum 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 MMXCore Routines 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “MMXCore.8bx”
                 Mosaic Tiles 19.1.0 - from the file “Filter Gallery.8bf”
                 Multiprocessor Support 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “MultiProcessor Support.8bx”
                 Neon Glow 19.1.0 - from the file “Filter Gallery.8bf”
                 Note Paper 19.1.0 - from the file “Filter Gallery.8bf”
                 NTSC Colors 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “NTSC Colors.8bf”
                 Ocean Ripple 19.1.0 - from the file “Filter Gallery.8bf”
                 OpenEXR 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Paint Daubs 19.1.0 - from the file “Filter Gallery.8bf”
                 Palette Knife 19.1.0 - from the file “Filter Gallery.8bf”
                 Patchwork 19.1.0 - from the file “Filter Gallery.8bf”
                 Paths to Illustrator 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 PCX 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “PCX.8bi”
                 Photocopy 19.1.0 - from the file “Filter Gallery.8bf”
                 Photoshop 3D Engine 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Photoshop3DEngine.8bi”
                 Photoshop Touch 19.0 - from the file “PSDX.8bi”
                 Picture Package Filter 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “ChannelPort.8bf”
                 Pinch 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Pixar 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Pixar.8bi”
                 Plaster 19.1.0 - from the file “Filter Gallery.8bf”
                 Plastic Wrap 19.1.0 - from the file “Filter Gallery.8bf”
                 PLY 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Pointillize 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Polar Coordinates 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Portable Bit Map 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “PBM.8bi”
                 Poster Edges 19.1.0 - from the file “Filter Gallery.8bf”
                 PRC 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Radial Blur 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Radiance 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Radiance.8bi”
                 Range 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Render Color Lookup Grid 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Export3DLUT.8be”
                 Reticulation 19.1.0 - from the file “Filter Gallery.8bf”
                 Ripple 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Rough Pastels 19.1.0 - from the file “Filter Gallery.8bf”
                 Save for Web 19.1.0 - from the file “Save for Web.8be”
                 ScriptingSupport 19.1.0 - from the file “ScriptingSupport.8li”
                 Shake Reduction 19.1.0 - from the file “Shake Reduction.8bf”
                 Shear 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Skewness 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Smart Blur 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Smudge Stick 19.1.0 - from the file “Filter Gallery.8bf”
                 Solarize 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “Solarize.8bf”
                 Spaces 19.1.0 - from the file “Spaces.8li”
                 Spatter 19.1.0 - from the file “Filter Gallery.8bf”
                 Spherize 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Sponge 19.1.0 - from the file “Filter Gallery.8bf”
                 Sprayed Strokes 19.1.0 - from the file “Filter Gallery.8bf”
                 Stained Glass 19.1.0 - from the file “Filter Gallery.8bf”
                 Stamp 19.1.0 - from the file “Filter Gallery.8bf”
                 Standard Deviation 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 STL 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Sumi-e 19.1.0 - from the file “Filter Gallery.8bf”
                 Summation 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Targa 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Texturizer 19.1.0 - from the file “Filter Gallery.8bf”
                 Tiles 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Torn Edges 19.1.0 - from the file “Filter Gallery.8bf”
                 Twirl 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 U3D 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Underpainting 19.1.0 - from the file “Filter Gallery.8bf”
                 Vanishing Point 19.1.0 - from the file “VanishingPoint.8bf”
                 Variance 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “statistics.8ba”
                 Virtual Reality Modeling Language | VRML 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 Water Paper 19.1.0 - from the file “Filter Gallery.8bf”
                 Watercolor 19.1.0 - from the file “Filter Gallery.8bf”
                 Wave 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Wavefront|OBJ 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “U3D.8bi”
                 WIA Support 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “WIASupport.8li”
                 Wind 19.1.0 - from the file “Standard MultiPlugin.8bf”
                 Wireless Bitmap 19.1.0 (20180116.r.238 2018/01/16: 1153018) - from the file “WBMP.8bi”
                 ZigZag 19.1.0 - from the file “Standard MultiPlugin.8bf”
              Optional and third party plug-ins:
                 Analog Efex Pro 2 2.0.12.12 - from the file “C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
                 BackgroundFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
                 Color Efex Pro 4 4.3.24.12 - from the file “C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
                 Dfine 2 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
                 FineStructuresFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
                 HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
                 HotPixelsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
                 Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
                 Nik Collection Selective Tool 2.1.28 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\Google\Selective Tool\SelectivePalette.8li”
                 ShadowsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
                 Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
                 Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
                 Silver Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
                 SkinFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
                 SkyFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
                 StrongNoiseFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
                 Viveza 2 2.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
              Duplicate and Disabled plug-ins: NONE
              Plug-ins that failed to load: NONE
              Extensions:
                 com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                 com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                 Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                 New Document  2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html”
                 Start  2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html”
                 Coolorus 2․5  2.5.12 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.moongorilla.coolorus2\index.html”
                 Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                 Export As  3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
              Installed TWAIN devices: NONE
              • 4. Re: Rotate tool and liquify don't work
                Bereh Level 1
                Hi, JJMack!
                The Graphic Processor is checked in my Preferences Performance.
                Actually, if it is on or off, the tool rotate does not work anyway...
                About the liquify filter, if GPU is checked, the filter does not work, if it is unchecked, it works with restrictions...
                • 5. Re: Rotate tool and liquify don't work
                  I would check the Intel site to see if the is a newer device driver for your Intek HD Graphic 5500 chip the one you have install is dataed 2016.....
