8 Replies Latest reply on Feb 11, 2018 11:22 AM by ExtraMurque
    Toggle options in Publish settings with Javascript Code?
    ExtraMurque Level 1
      Hello Community,
      I seem not be able to find the javascript code for an automated toggle of an option in the Publish settings.
      For months I am looking for some script codes, but without success.
      I need to export multiple layers as a separate .swf file, per created Animate document.
      So I need to manually deselect the option here:
      In the File > Publish Settings menu, switch to the Advanced tab: Include hidden layers.
      I cannot find the javascript code to access this, or the complete codes to change the Quality and the Include hidden layers.
      Is there a possibility to have some lines of codes (that someone already found out somehow...), that I can glue just
      before I launch my Layer-Export-Script?
      Could you help me out?
      Any suggestions are greatly appreciated.
      Marc.
      Here is the code of the Export Layers Script as I have it now:
      var doc = fl.getDocumentDOM();
      var docTimeline = doc.getTimeline();
      var exportName;
      var layerNum;
      var layerSelection = docTimeline.getSelectedLayers();
      var layers = new Array();
      var count = 0
      var moreThanTenLayers = false
      var numberLayers = 0
      var folder = fl.browseForFolderURL("Choose an output directory");
      var docfoldername = doc.name
      if (docfoldername.slice (20,21) == "." || docfoldername.slice (20,21) == "_")
          var exportDest = folder+ "/" +"EXPORT_" + docfoldername.slice (4,20)
      }else{
          var exportDest = folder+ "/" +"EXPORT_" + docfoldername.slice (4,21)
      FLfile.createFolder(exportDest)
      // sort selection by layer index
      for ( var i=0;i<layerSelection.length;i++ )
          for ( var j=0;j<layerSelection.length;j++ )
              if (layerSelection[i] < layerSelection[j])
                  var temp = layerSelection[i];
                  layerSelection[i] = layerSelection[j];
                  layerSelection[j] = temp;
      for ( var it=0;i<layerSelection.length;it++ ) {
         var p = docTimeline.layers[layerSelection[it]]
          var layerName2 = p.name; //determinate file name
          if(layerName2.indexOf("#")>-1){
          else{
              numberLayers = numberLayers + 1
          if (numberLayers >9){
             moreThanTenLayers = true
          // hide all layers but current
          for ( var j=0;j<docTimeline.layerCount;j++ )
              //only deal with normal visible layers, remember their index
              if ( docTimeline.layers[j].visible == true && docTimeline.layers[j].layerType == "normal")
                  layers.push (j);
                  docTimeline.layers[j].visible = false;
              } else {
          // show layer
          var l = docTimeline.layers[layerSelection[i]]
          l.visible = true;
          var layerName = l.name; //determinate file name
          // export only one image if layer is the frame
          if (layerName.indexOf("#")>-1){
          else{
          if (layerName.indexOf('CADRE')> -1 || layerName.indexOf('cadre')> -1 || layerName.indexOf('SECU')> -1 || layerName.indexOf('secu')> -1 || layerName.indexOf('BOARD')> -1 || layerName.indexOf('board')> -1 || layerName.indexOf('CACHE')> -1 || layerName.indexOf('cache')> -1 || layerName.indexOf('animatique')> -1 || layerName.indexOf('ANIMATIQUE')> -1)
              fl.getDocumentDOM().getTimeline().setLayerProperty('layerType', 'normal');
              if (moreThanTenLayers = true){
              exportName = exportDest + "/" + "000" + "__" + layerName
          else{
               exportName = exportDest + "/" + "00" + "__" + layerName
              doc.exportSWF(exportName , true , true);
          else
              // padding 0s
              var padding = "0"+count
              }else{
              var padding = "00"+count
              exportName = exportDest + "/" + padding + "_" + layerName;
              doc.exportSWF(exportName , true , false);
              count += 1;
          l.visible = false;
      //resets visibility
      for ( var i=0;i<docTimeline.layerCount;i++ )
          docTimeline.layers[i].visible = true
      doc.close(SaveOptions = 0)
        • 2. Re: Toggle options in Publish settings with Javascript Code?
          ExtraMurque Level 1
          Hello and thank you for the link.
          This part works indeed, that is if you have created a profile inside Flash already:
          var profileXML=fl.getDocumentDOM().exportPublishProfileString('theCreatedNewProfileWithinFlas h');
          fl.trace(profileXML);
          var newProfileXML = profileXML.replace("<ActionScriptVersion>2</ActionScriptVersion>", "<ActionScriptVersion>1</ActionScriptVersion>");
          fl.getDocumentDOM().importPublishProfileString(newProfileXML);
          But somehow I seem not able to import the .apr file inside flash before using the above lines of code...
          var xmlString = "C:\Users\Windows\AppData\Local\Adobe\Animate CC 2017\en_US\Configuration\Publish Profiles\theSavedProfileFile.apr"
          document.importPublishProfileString(xmlString)
          Is this the right approach?
          Cheers,
          Marc
          • 3. Re: Toggle options in Publish settings with Javascript Code?
            ExtraMurque Level 1
            P.s.
            Maybe good to mention is that the .fla files are made by other people on different computers/ profiles.
            This could mean that the reason why I cannot keep my own created profile on my computer when opening the Flash-files from the Animation-Production-server is that the created version is made with different settings...
            • 4. Re: Toggle options in Publish settings with Javascript Code?
              JoãoCésar Adobe Community Professional
              Hi.
              What I think you need is a script to export your current publish profile settings and then run a script that imports this newly created profile and then export the layers as SWFs.
              I used this technique to export FLAs to SVGs here: Re: Script to automate a repetitive task in Animate? .
              1 - Run this script (export_publish_profile.jsfl) to export whatever publish settings you want:
              var publishProfileName = "fl_publish_profile.xml";
              function exportPublishProfile()
                  if (fl.getDocumentDOM())
                      fl.getDocumentDOM().exportPublishProfile(fl.scriptURI.replace(fl.scriptURI.split("/").pop(), publishProfileName));
              exportPublishProfile();
              2 - Run this script (export_layers_as_swf.jsfl) to export the SWFs to the desired location:
              function exportFromLayers()
                  var doc;
                  var folder;
                  var profileIndex;
                  var layers;
                  var layersIndexes;
                  if (!doc)
                      return;
                  folder = fl.browseForFolderURL("Choose an output directory.");
                  if (!folder)
                      return;
                  try
                      profileIndex = doc.importPublishProfile(fl.scriptURI.replace(fl.scriptURI.split("/").pop(), publishProfileName));
                      doc.currentPublishProfile = fl.getDocumentDOM().publishProfiles[profileIndex];
                      layers = doc.getTimeline().layers;
                      layersIndexes = doc.getTimeline().getSelectedLayers();
                      for (var i = 0, total = layersIndexes.length; i < total; i++)
                          layers[layersIndexes[i]].visible = false;
                      for (i = 0; i < total; i++)
                          var layer = layers[layersIndexes[i]];
                          layer.visible = true;
                          doc.exportSWF(folder + "/" + zeropad(i, 2) + "_" + layer.name + ".swf", true);
                          layer.visible = false;
                      doc.deletePublishProfile();
                  catch(error)
                      fl.trace("\n----------");
                      fl.trace(error);
                      fl.trace("Error when loading publish profile. It should be in the same folder where this script is located and should be called " + publishProfileName);
                      fl.trace("----------\n");
              function zeropad(number, length) {
                  var str = '' + number;
                  while (str.length < length)
                      str = '0' + str;
                  return str;
              exportFromLayers();
              Scripts download:
              export_layers_as_swf.zip - Google Drive
              I hope it helps.
              Regards,
              JC
              2 people found this helpful
              • 5. Re: Toggle options in Publish settings with Javascript Code?
                ExtraMurque Level 1
                Thank you so much João!
                That did the trick!
                Really appreciated!
                Have a great weekend!
                Marc
                • 6. Re: Toggle options in Publish settings with Javascript Code?
                  ClayUUID Adobe Community Professional
                  No, there is always a Default profile available.
                  This JSFL code will make the publish profile changes you wanted:
                  var dom = fl.getDocumentDOM();
                  // grab current profile
                  var profileXML = dom.exportPublishProfileString(dom.currentPublishProfile);
                  // modify profile
                  // WARNING: This is a hack that does direct string manipulation instead of properly parsing the XML
                  // exclude hidden layers (Flash)
                  profileXML = profileXML.replace(/<InvisibleLayer>.<\/InvisibleLayer>/g, '<InvisibleLayer>0</InvisibleLayer>');
                  // exclude hidden layers (HTML/SVG)
                  profileXML = profileXML.replace(/<Property name="includeHiddenLayers">.+?<\/Property>/g, '<Property name="includeHiddenLayers">false</Property>');
                  // JPEG quality
                  profileXML = profileXML.replace(/<Quality>.+?<\/Quality>/g, '<Quality>100</Quality>');
                  // apply updated profile
                  dom.importPublishProfileString(profileXML);
                  • 7. Re: Toggle options in Publish settings with Javascript Code?
                    This is great, Marc!
                    You're welcome!
                    • 8. Re: Toggle options in Publish settings with Javascript Code?
                      ExtraMurque Level 1
                      Thank you for the information.
                      Marc
