2 Replies Latest reply on Feb 12, 2018 12:26 PM by jeromiec83223024
    Issues with Windows 10, IE11, Flash, and JAWS Combination
    christopherw17421722
      Good Afternoon,
      We are experiencing the following issue while trying to test a Flash application on Windows 10 while using JAWS:
      A Flash application uses “ExternalInterface.call” to call a JavaScript function and passes an argument of a URL string. The JavaScript function uses “window.open” to open a new browser window with the URL. This causes Internet Explorer 11 to freeze and display the following message “A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.” Both the base screen that has the Flash file and the popup refresh.
      This issue only occurs while using JAWS, Windows 10, Flash, and IE11. This does not happen on Windows 7.
      Specs of Computer with issue:
      • Windows 10
      • IE 11
      • JAWS 2018
      • Flash Player Version 28.0.0.161
