6 Replies Latest reply on Feb 10, 2018 10:54 AM by ethandale
    Artboard size warning spam
    ethandale Level 1
      Whenever I make an artboard, it allows me to make it, and then when I try and switch to any other tool, it starts freaking out, spamming me with "invalid size, value must be between 1% and 32,000%" (by the way, it's always between 100% and 3,000%, so nowhere close where the warning is) and I have to click the OK button 5-20 times to get the warning to disappear. After that, it works fine. Sometimes it resizes and breaks the artboard, but normally it just leaves it exactly how it is and how I wanted it. Does anyone know why this might be happening?
        • 1. Re: Artboard size warning spam
          Theresa J Adobe Community Professional
          Can you post a screen capture of your workspace with the warning?
          • 2. Re: Artboard size warning spam
            ethandale Level 1
            Sorry for the late reply, here is a screenshot right after I switched to the move tool. It automatically changed my width value to 1% from 3,000 some percent. From here, I click the OK button 9 times, and then it looks like the second picture.
            • 3. Re: Artboard size warning spam
              What are the two smaller boxes inside of artboards 1 & 2? They look like smaller nested artboards which doesn’t make sense. I’m not sure if this is your problem or not.
              The options bar at the top of the first screen capture shows the width is only 1%. This is causing the message. Interestingly the properties panel doesn’t match the options bar. They usually always match. Try changing the artboards dimensions to pixels instead of percentage in the properties panel. What are the pixel dimensions for the selected artboard? Does the options bar match the property panel?
              • 4. Re: Artboard size warning spam
                ethandale Level 1
                Those are just storyboards, they're layers inside of the artboards.
                I changed it to pixels by selecting Android instead, and once I did that, the properties window matched the options bar. The thing that was saying 1% didn't say 1% until after I clicked the move tool. It was 3,100% before. After I switched to move, it said it needs to be between 1% and 32,000%, and then changed the percent to 1. After clicking OK the first time, it changed the other percent to 1 as well. It never matched the properties window until I changed it to pixels. I'll probably just report it as a bug, because even if it was the sizing issue in percent, the values that I had after converting the layers to an artboard were still within the specified range, so the error message should not have happened.
                • 5. Re: Artboard size warning spam
                  I agree that the error message along with the % setting is probably a bug. Did changing the dimensions to pixels instead of percentage fix the problem?
                  • 6. Re: Artboard size warning spam
                    ethandale Level 1
                    Yeah, it did. Thanks!
