• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ExtendScript limit on how many paragraphs can be processed
Community Expert ,
Feb 07, 2018 Feb 07, 2018
I received a bug report on my FindChangeFormatsBatch ExtendScript script yesterday where the issue was a crash on two particular documents. Both documents contain a large amount of tables and, because each cell contains at least one paragraph, a large number of paragraphs. One document had over 12,000 paragraphs and the other over 14,200 paragraphs.
I still wasn't sure if the number of paragraphs was the problem so I set up a simple, Portrait document containing a large number of paragraphs. Each paragraph was empty except for an autonumber so I could keep track of the number of paragraphs. Here is the code I ran:
#target framemaker
var doc = app.ActiveDoc;
countPgfs (doc);
function countPgfs (doc) {
    var pgf, counter = 0;
    pgf = doc.FirstPgfInDoc;
    while (pgf.ObjectValid () === 1) {
        counter += 1;
        pgf = pgf.NextPgfInDoc;
    alert (counter);
The code always ran the first time, even with over 14,000 paragraphs in the document. But it would hang and crash FrameMaker if I tried to run it a second time. I cut my paragraph count back until I could run it over and over without hanging. I ended up at around 12,200 paragraphs, give or take a few. Once I got over that mark, FrameMaker would hang on the second run of the script.
I wonder if anyone else has experimented with ExtendScript and processing large numbers of paragraphs. Any feedback or comments will be appreciated.
-Rick
TOPICS
Scripting
Views
763
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Feb 08, 2018 Feb 08, 2018
This is a Memory leak in ExtendScript Core and related to all Adobe Products using ExtendScript.
This doesn't effect FDK Clients/plugins and so this has no side effects to FrameScript.
Hopefully Adobe will solve this Problem very soon. Traversing all paragraphs in a document is a very common use case.
Votes
Translate
Translate
Enthusiast ,
Hi Rick,
this is a known bug.
Re: Framemaker 12 and Framemaker 15 get stuck after one complete traversal of all Paragraphs in the ...
I've tested it several times. After about 500 Pgfs FrameMaker crashes.
Votes
Translate
Translate
Report
Report
Community Expert ,
Thank you Klaus. I forgot about that thread. I have a lot of scripts that completely traverse all paragraphs that don't stall, except when the number of paragraphs gets large.
Votes
Translate
Translate
Report
Report
Community Expert ,
Is this bug also in FrameScript or only in ExtendScript?
Best regards
Winfried
Votes
Translate
Translate
Report
Report
Enthusiast ,
Hi Winfried,
I suppose, that it's only in ExtendScript.
Because @Stefan_Gentz wrote (see my link above)
We have investigated this further, and this bug is in ExtendScript and not FrameMaker.
Votes
Translate
Translate
Report
Report
Engaged ,
Votes
Translate
Translate
Report
Report
Community Expert ,
Thank you guys for clearing this up. Just to clarify: I have hundreds of ExtendScript scripts that traverse all of the paragraphs in a document and these normally work without failure. The failure comes when the number of paragraphs in the document is large, somewhere around 12,000 or so. Thanks again!
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
open Taskmanager and see what happens....
Memory increases and perhaps on 12,000 pgfs it crashes as Memory Limit for 32bit applications is reached.
May be it happens with 5,000 pgf if your scripts allocates Memory for other objects (markers) in same run.
In my experience Memory is deallocated again, when script is finished.
Votes
Translate
Translate
Report
Report
