3 Replies Latest reply on Feb 13, 2018 1:22 AM by sylvainr61802075
    Signature validation between Acrobat XI and DC
      We produce a qualified digital signature from Acrobat Reader and we have a different result during the validation process between Acrobat Reader XI and Acrobat Reader DC.
      The first one manages to validate the signature and the second one generate an error (see below).
      That is the same document, with the same signature and qualified certificate.
      Like we use a Certificate Authority referenced into the European Trusted List, our qualified certificate uses the following QCstatement :
          0:d=0  hl=2 l= 125 cons: SEQUENCE
          2:d=1  hl=2 l=   8 cons: SEQUENCE
          4:d=2  hl=2 l=   6 prim: OBJECT :
         12:d=1  hl=2 l=   8 cons:  SEQUENCE
         14:d=2 hl=2 l=   6 prim: OBJECT :
      22:d=1  hl=2 l=  80 cons: SEQUENCE
         24:d=2 hl=2 l=   6 prim: OBJECT :
      32:d=2  hl=2 l=  70 cons: SEQUENCE
         34:d=3 hl=2 l=  68 cons: SEQUENCE
         36:d=4 hl=2 l=  66 cons: SEQUENCE
         38:d=5 hl=2 l=  60 prim: IA5STRING :https://www.preuve-electronique.org/ListeRevocations/cgu.pdf
      100:d=5  hl=2 l=   2 prim: PRINTABLESTRING   :en
      104:d=1  hl=2 l=  21 cons: SEQUENCE
        106:d=2 hl=2 l=   6 prim:   OBJECT :
      114:d=2  hl=2 l=  11 cons: SEQUENCE
        116:d=3 hl=2 l=   9 cons: SEQUENCE
        118:d=4 hl=2 l=   7 prim: OBJECT :
      We don't really understand why the same document produces different result during the validation process between the two versions of the Reader.
      Is there a reason?
