I am not able to install Adobe In Design Snap Ins.
I need to open SOP port via this.
I am using below command. But it shows command is not correct.
C:/ AdobeInDesignCS64 Server> regsvr64 InDesignServerMMC64.dll
Can you please help?
I had the same problem tonight... used regsvr32 instead of regsvr64 and it succeeded
I did but still it show not installed. MMC Snap Ins is not working. Kindly advise.
Hello, I have no 32 bit MMC dll in Adobe server. My version in x 64.
so I can not use regsvr32. MMC Console is not working and not installed.
It is very urgent for opening port which will sync with Doc Maker.
Hello,
I should have shown you exactly what I meant... Here is what I did:
C:\Program Files\Adobe\Adobe InDesign CC Server 2018>regsvr32 InDesignServerMMC64.dll
C:\Program Files\Adobe\Adobe InDesign CC Server 2018>mmc
I don't have x32 dll either but it worked with the regsvr32 command. Then started up MMC and added the InDesignServerService and then started a few instances.
Hope this helps.
Blake
