hello forum.
i don't undestand why ES does not restitute correctly the data i input in the array.
i use the code of the export of "ExtendScript of the Week: Import and Export Variables "
i need to change the output . I want on one line all the variables for a same file .
so i add this function to move from vertical to horizontal display. i send after to a function that log in a file
function TransfertTo_DZG_Table(VariableData){
var tableVariableName= new Array("Model", "ManualType", "ManualNumber", "B_ChapterName","B_ChapterNumber", "B_SectionName", "B_SectionNumber","Item Number", "Item Name","Doc Status");
var tableFileName = new Array();
var tableVariable =new Array();
var VariableValue;
tableVariable.variableCount = 0;
$.writeln ("longueur tableau="+VariableData.chapterNameArray.length);
// table initialisation
$.writeln ("--------------------start of table initialisation---------------------");
for(boucle1=0;boucle1<VariableData.chapterNameArray.length;boucle1++){
for(boucle2=0;boucle2<30;boucle2++){
tableVariable[boucle1,boucle2]="---";
$.writeln ("--------------------end of table initialisation-----------------------");
// end of initialisation
// table filling
$.writeln ("*************************start of filling******************");
//for(var i = 0; i < VariableData.chapterNameArray.length; i++){
for(var i = 0; i < 50; i++){ // temporary to have less result
var FileName=File(VariableData.chapterNameArray[i ]).displayName;
var VariableName=VariableData.variableNameArray;
var VariableValue=VariableData.variableDefArray[i ];
var IndexFileName=GetIndexOf(tableFileName, FileName);
var IndexVariableName=GetIndexOf(tableVariableName, VariableName);
if(IndexFileName == -1){
tableFileName.push(FileName);
$.writeln("nouveau fichier"+ FileName+"index nouveau fichier"+IndexFileName);
if(IndexVariableName== -1){
tableVariableName.push( VariableName);
if(VariableValue===undefined){
VariableValue="_";
tableVariable[IndexFileName,IndexVariableName]=VariableValue;
$.writeln("-------tableVariable["+IndexFileName+","+IndexVariableName+"]="+VariableValue);
$.writeln ("*******************end of filling**********************");
// end of filling
// loop to check value inside table
$.writeln ("////////////////////////////check of the table//////////////////////////");
for(boucle1=0;boucle1<5;boucle1++){
$.writeln( "=============boucle1="+ boucle1+"============");
for(boucle2=0;boucle2<10;boucle2++){
$.writeln("tableVariable["+boucle1+","+boucle2+"]="+ tableVariable[boucle1,boucle2]);
$.writeln ("////////////////////////////////////end of check///////////////////////////");
// end of loop
//FcWriteTableau(tableVariable);
//ExtractTableau(tableFileName,tableVariableName,tableVariable);
entre dans ExportVariable
longueur tableau=105
nouveau fichierTitlePage_FAA_MDDG.fmindex nouveau fichier0
-------tableVariable[0,10]=XXXXXX
-------tableVariable[0,11]=The xxxxxxx Company
-------tableVariable[0,12]=Title Template
-------tableVariable[0,5]=Preface
-------tableVariable[0,6]=E
-------tableVariable[0,3]=Title Page_DZG
-------tableVariable[0,4]=1
-------tableVariable[0,13]=14
-------tableVariable[0,0]=123
-------tableVariable[0,14]=2017
-------tableVariable[0,2]=A630Z004-01
-------tableVariable[0,15]=2013
-------tableVariable[0,9]=
-------tableVariable[0,16]=Dispatch Deviations Guide (DDG)
-------tableVariable[0,1]=Dispatch Deviations Guide
-------tableVariable[0,17]=Jul 20, 2017
nouveau fichierP-00-00TOC.fmindex nouveau fichier1
-------tableVariable[1,1]=Dispatch Deviations Guide
-------tableVariable[1,7]=00
-------tableVariable[1,9]=
-------tableVariable[1,2]=B630Z004-02
-------tableVariable[1,0]=456
-------tableVariable[1,3]=Section List_V
-------tableVariable[1,5]=Preface_V
-------tableVariable[1,6]=E
-------tableVariable[1,17]=Jul 20, 2017
nouveau fichierP-00-01-00_FAA.fmindex nouveau fichier2
-------tableVariable[2,1]=Dispatch Deviations Guide
-------tableVariable[2,18]=10
-------tableVariable[2,9]=
-------tableVariable[2,13]=14
-------tableVariable[2,2]=C630Z004-03
-------tableVariable[2,19]=14
-------tableVariable[2,0]=789
-------tableVariable[2,7]=00-01-00
-------tableVariable[2,3]=Revision Record_V
-------tableVariable[2,5]=Preface_V
-------tableVariable[2,6]=E
-------tableVariable[2,20]=Rev Rec
-------tableVariable[2,21]=D630Z004-01
-------tableVariable[2,22]=XX
-------tableVariable[2,23]=D630Z004-XXX
nouveau fichier4-00-00TOC.fmindex nouveau fichier3
-------tableVariable[3,1]=Dispatch Deviations Guide
-------tableVariable[3,0]=963
-------tableVariable[3,2]=D630Z004-01
-------tableVariable[3,20]=General_V
-------tableVariable[3,6]=H
-------tableVariable[3,7]=00
-------tableVariable[3,5]=Miscellaneous_V
-------tableVariable[3,9]=
-------tableVariable[3,17]=Jul 20, 2017
nouveau fichier4-00-01-00.fmindex nouveau fichier4
-------tableVariable[4,19]=MML Revision Number
=============boucle1=0============
tableVariable[0,0]=963
tableVariable[0,2]=D630Z004-01
tableVariable[0,3]=Revision Record_V
tableVariable[0,5]=Miscellaneous_V
tableVariable[0,6]=H
tableVariable[0,7]=00
tableVariable[0,8]=---
tableVariable[0,9]=
=============boucle1=1============
tableVariable[1,0]=963
tableVariable[1,2]=D630Z004-01
tableVariable[1,3]=Revision Record_V
tableVariable[1,4]=1
tableVariable[1,5]=Miscellaneous_V
tableVariable[1,6]=H
tableVariable[1,8]=---
tableVariable[1,9]=
=============boucle1=2============
tableVariable[2,0]=963
tableVariable[2,2]=D630Z004-01
tableVariable[2,4]=1
tableVariable[2,5]=Miscellaneous_V
tableVariable[2,6]=H
tableVariable[2,8]=---
tableVariable[2,9]=
=============boucle1=3============
tableVariable[3,3]=Revision Record_V
tableVariable[3,4]=1
tableVariable[3,8]=---
tableVariable[3,9]=
=============boucle1=4============
tableVariable[4,0]=963
tableVariable[4,1]=Dispatch Deviations Guide
tableVariable[4,2]=D630Z004-01
tableVariable[4,3]=Revision Record_V
tableVariable[4,4]=1
tableVariable[4,5]=Miscellaneous_V
tableVariable[4,6]=H
tableVariable[4,7]=00
tableVariable[4,8]=---
tableVariable[4,9]=
RĆ©sultat : undefined
So how do you manage multidimensionnal array
i can't do like "extend of the week " as i don't know number of variables nor number of files.
thank
hello forum
i have found the response here :
How to create a multi dimensional array in Javascript? - Stack Overflow .
to have mutidimensionnal array we have to declare an array in an another array .
here the final code:
var tab
...Copy link to clipboard
hello forum
var VariableValue;
// table filling
// for(var i = 0; i < 50; i++){ // temporary
tableVariable[IndexFileName]=new Array();
VariableValue="_";
tableVariable[IndexFileName][IndexVariableName]=VariableValue;
//$.writeln("-------tableVariable["+IndexFileName+","+IndexVariableName+"]="+VariableValue);
// end of filling
regards
