0 Replies Latest reply on Feb 13, 2018 11:23 AM by jeremyd10247453
    Acrobat Standard DC - Intermittent insufficient data for an image & Blank Scrolling
    jeremyd10247453
      Hello I am seeing the following behavior on some user sessions.  Intermittently with different PDFs they will sometimes scroll and seeing nothing but blank pages.  After that they got a prompt with the following "insufficient data for an image".  Most of the time they can close the document without an issue but sometimes when they close adobe will crash.  with the below.  After they close and reopen the document everything works fine and they can view all the pages until the next time a random document causes the issue.  It happens almost daily and doesn't seem to be an issue with the document as it opens fine but then throws the error after scrolling through.  And the fact that closing and opening it again works fine.  This was also an issue with Acrobat XI.
      What is causing this intermittent behavior?   This is a brand new install of Acrobat Standard DC.
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: Acrobat.exe
      Insufficient Data for an Image
      Application Version: 18.9.20050.57426
        Application Timestamp: 5a1c7469
        Fault Module Name: StackHash_5861
        Fault Module Version: 0.0.0.0
        Fault Module Timestamp: 00000000
        Exception Code: c0000005
        Exception Offset: PCH_17_FROM_ntdll+0x0003C8AC
        OS Version: 6.3.9600.2.0.0.144.8
        Locale ID: 1033
        Additional Information 1: 5861
        Additional Information 2: 5861822e1919d7c014bbb064c64908b2
        Additional Information 3: d2dd
        Additional Information 4: d2ddcae25462e2b2f29684f70c88f75a
      I also see the following error intermittently:
      “There was a problem reading this document (109)”
      Message was edited by: Jeremy Davies Updated Error message
