• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Acrobat Pro DC (Mac) will not scan unless attaching to existing document
New Here ,
Feb 08, 2018 Feb 08, 2018
If I want to start a scan from scratch, I go to File>Create>PDF from Scanner. When I do that, nothing happens. Scanner is fully operational and connected to computer. I can scan with other programs. I can also scan if I open a PDF first and then go to File>Create>PDF from Scanner.
This only doesn't work when I want to scan a document without attaching the new scan to an existing PDF.
TOPICS
Scan documents and OCR
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hello gbr94303
We apologize for the inconvenience caused, as per the description above, you are not able to scan from Acrobat Pro DC on a Mac machine, Is that correct?
Please check for any pending updates of Acrobat Pro from help>check for updates. Reboot the machine after the installation of any updates. Try resetting the preferences once, to reset preferences, refer to How to reset Acrobat Preference settings to default. Link: https://forums.adobe.com/docs/DOC-8511
Reboot the machine and see if this brings any difference. You can also refer to Troubleshooting tips for scanner issues when using Acrobat Link: https://helpx.adobe.com/acrobat/kb/troubleshoot-scanner-issues-acrobat.html
If the issue persists, please share the following details:
Let us know how it goes and share your findings.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 10, 2018 Feb 10, 2018
Thanks, The problem persisted.
I already had confirmed that I had the latest version of AP DC. I had also re-downloaded and re-installed the most current scanner driver. I’m using Mac OS High Sierra, V.10.13.3 on a MBPro (15 inch, 2017), with a Brother MFC-9970CDW.
Unfortunately, in an effort to get a clean start, I figured I would uninstalled AP DC and install a clean version. I uninstalled using the uninstaller in the AP DC folder in the Applications folder. I cannot re-install it. I downloaded the .dmg file from the Adobe website. After running it, I got an error message. See attached screenshot. I looked in my User/Library for Acrobat preferences and Application Support, but don’t know which might be relevant to the installation.
Now what???
George Richardson
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Apr 06, 2018 Apr 06, 2018
Hello Gbr,
Sorry for the delayed response and inconvenience caused. Please reboot the machine, then use Acrobat cleaner tool to remove Acrobat completely from the machine Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Reboot the machine again and install Acrobat back from Download Pro or Standard versions of Acrobat DC | Non-subscription
If the issue still persists, please create a test user profile with full admin rights, and check with Acrobat and let us know how it goes in a new user profile.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 23, 2018 Feb 23, 2018
im having the same issue, but will start to scan if i let it sit for a few mins. If i tell it to append to a open file it scans like normal, if i uncheck that it takes 3-5 mins for it to start scanning.
EDIT:
noticed if its file i extracted then saved - it still has a delay in scanning, but if i just keep scanning into a existing it works like it did before last patch
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello Sl00thy,
Sorry for the delayed response and inconvenience caused. If you have tried all the suggestions and steps shared above, and the issue still persists, please create a test user profile with full admin rights and check.
Let us know how it goes in a new test user profile.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 07, 2019 Nov 07, 2019
LATEST
I have this issue too... all the time, with an Epson ES-400
What's the problem?
Votes
Translate
Translate
Report
Report
