I have an image with two layers.
The bottom layer is full red i.e. rgb = (255, 0, 0) and 100% opaque
The top layer is black (0, 0, 0) with opacity 50% and blend mode normal.
I expect and need the result to be exactly half way between black and red, i.e. rgb = (128, 0, 0) or maybe rgb = (127, 0, 0), depending on rounding.
Instead I get (187, 0, 0).
Now I have two questions:
1. What is the rationale for this surprising behaviour? Other graphics software I have checked give me the result I expect, Photoshop does not.
2. The import one: Can I configure Photoshop to handle transparency the way I expect it to? So that the resulting color is determined by the "obvious" formula
result = ((255 - alpha) * base + alpha * top) / 255 ?
Just looked at colour settings. You haven't got "Blend RGB Colours using Gamma 1.00" checked have you?
If so uncheck it.
Dave
What color mode and color space are you using?
I get 127,0,0 here:
Dave
If so uncheck it.
Dave
@davescm: Thanks for your reply! Are these the settings you asked for?
@davescm: Thank you, that was it!
You're welcome - glad it is sorted now
Dave
