Hello,
I have an action that I run with batch process in Photoshop, I'll quickly describe it's uses for clarity. The action takes an image, exports it as JPG and PNG at full resolution, then resizes the image smaller, exports it as JPG and PNG (in different folders to previously), and then closes the file without saving.
I've been using this a lot for my images and it has always worked perfectly, I can select a folder full of any images, PSD, jpg, png - any format - and leave it processing, no need to do anything, just saves everything down how I want it.
However: I have a load of TIF files from an external company, and I tried to batch process them using my saved action... it completed the first action and saves it as a full resolution JPG, and then pops up with a dialogue box asking me to save as?? And no matter what I've tried, it won't go any further - if I cancel it and continue the action, it doesn't carry on and save the PNG down, just does the same thing on the next image. If I save it as a copy, again, it doesn't save the PNG down. I tried converting all the TIF's into PSD files using the image processor and batch processing the PSD's, but same thing happens.
I've tried batch processing a completely different folder of PSD's from a previous job, and the action works perfectly on them, so I'm wondering why it won't work with these particular images??? Never had a problem before...
Has anyone run into anything similar before, or have any advice or help?? I have a lot of these images to process and can't do it manually!
Really appreciate any help.
If that is what happen with those Tiff and your action we would need both you action and some sample tiff you have problems with to see where your problem is. Most likely the problem is in your action on how you set the batch options.
You do not need any Action to do what you what you want. You could download and Install Image Processor Pro and use that. With that you can save out up to ten output image files for your files the type and size you need. Just add and remove tabs. You can if you
...Copy link to clipboard
You do not need any Action to do what you what you want. You could download and Install Image Processor Pro and use that. With that you can save out up to ten output image files for your files the type and size you need. Just add and remove tabs. You can if you needed include action for each output image produces to add additional custom processing.
Hello JJMack,
Excellent workaround, thanks for the advice, I've managed to get the job done. I would like to know why the issue is occuring though.
Here is the text for the action below, is this what you wanted? And here's a link to one of the PSD files: Adobe Creative Cloud
Action: Product Image Export
Set File Info of current document
To: file info
Rights Usage Terms: “All Rights Reserved”
Export
Using: Save for Web
Operation: Save
true
In: \\SERVER\Users\FolderRedirections\Tom\Working Media\EXPORT MEDIA\Product Images Export\EXPORT\High res JPEG\
Format: JPEG
Without Interlaced
Quality: 100
0
Quality Modification Channel Strength: 0
Without Quality Channel Text Layers
Without Quality Channel Vector Layers
With Optimized
Number Of Passes: 1
Blur: 0
With Matte
Without Embed ICC Profile
Matte Color Red: 255
Matte Color Green: 255
Matte Color Blue: 255
Without Save HTML File
With Save Image Files
Slices: All Slices
Color Handling: Convert to sRGB
Metadata: All Except Camera Info
Without Output XHTML
With Include Comments
With Always Add Alt Attribute
With Always Quote Attributes
Without Close All Tags
With Include Zero Margins on Body Tag
HTML Tags Case: Lowercase
HTML Attribute Case: Lowercase
HTML Indent: -1
HTML Line Endings: Automatic
<unknown>
Without Generate CSS
Empty Cells: GIF, IMG WH
TD WH: Auto
Vertical Spacer Cells: Auto (Bottom/Right)
Horizontal Spacer Cells: Auto (Bottom/Right)
Slice Name Components: Filename Component list
Filename Component
Filename Component Type: doc. name
Filename Component
Filename Component Type: underscore
Filename Component
Filename Component Type: layer name or slice no.
Filename Component
Filename Component Type: none
Filename Component
Filename Component
Without View As Background
Background Image Path: “”
Background Color Type: Matte
File Name Components: Filename Component list
Filename Component
Filename Component Type: slice name
Filename Component
Filename Component Type: hyphen
Filename Component
Filename Component Type: trigger name
Filename Component
Filename Component
Filename Component Type: rollover state
Filename Component
...3 More
Without Mac OS 9 Filename Compatibility
With Windows Filename Compatibility
With Unix Filename Compatibility
With Use Images Subfolder
With Copy Background Image when Saving
Images Subfolder Path: “images”
Save
As: PNG
Interlace: none
Filter: adaptive
Compression: 9
In: \\SERVER\RedirectedFolders\Tom\Working Media\EXPORT MEDIA\Product Images Export\EXPORT\High res PNG\
261
With Copy
Image Size
Width: 1200 pixels
With Constrain Proportions
Interpolation: automatic
Export
Using: Save for Web
Operation: Save
true
In: \\SERVER\Users\FolderRedirections\Tom\Working Media\EXPORT MEDIA\Product Images Export\EXPORT\Low res JPEG\
Format: JPEG
Without Interlaced
Quality: 80
0
With Optimized
Number Of Passes: 1
Blur: 0
With Matte
Slices: All Slices
HTML Indent: -1
<unknown>
TD WH: Auto
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
Filename Component
...3 More
Save
As: PNG
Interlace: none
Filter: adaptive
Compression: 9
In: \\SERVER\RedirectedFolders\Tom\Working Media\EXPORT MEDIA\Product Images Export\EXPORT\Low res PNG\
261
With Copy
Close
Saving: no
261
true
Tomy-rex wrote
Hello JJMack,
You wrote you were having problems with some Tiff files no problem with your PSD files???
Even If I had your action and Tiff I could not test for I could not connect to your remote sever your action is saving to unless you override save as in your batch setting which you did not post. Additionally Adobe does not officially state that Photoshop will work with network file servers. However, your problem is most likely related to Photoshop behavior. Actions can not use logic so they have a limited saving ability they came not use logic to generate filename they have to relies on Photoshop behaving a particular way. The problem is Photoshop behavior may change if all document conditions are not the same. I also do not use save for web is actions and it looks like you have here and I also do not know if save for web can be overridden when batched. I'm not familiar with Photoshop behavior when saved for web is used when an action is played.
No, I said that I tried to convert the TIF's into PSD's and the same issue happened again.... that's why I thought there must be something related to the file that was causing an issue. No worries though, thanks for the taking the time to reply and help out.
