7 Replies Latest reply on Jun 11, 2018 7:47 AM by bobbyjourdan
    Javascript in captivate
    craigs8411935 Level 1
      Hi all
      I am using this code
           var box = $('#restart_loop')[0]; cp.clickHandler(box);
      on an "on Enter" action for a slide in my captivate, it initiates an advanced action on a hidden button on the slide.
      this works perfectly, but I want to add a .oam object that I have built in adobe animate cc with a button that can also initiate the same function
      i would normally use:
           this.Reset.addEventListener("mousedown", fl_MouseClickHandler.bind(this));
           function fl_MouseClickHandler()
            window.parent.cpAPIInterface
      to control captivate from an animate object. so I tried:
      this did nothing so what I am wondering is how would I combine:
      with:
        • 1. Re: Javascript in captivate
          ClayUUID Adobe Community Professional
          This is the Adobe Animate forum. You want the Captivate forum.
          • 2. Re: Javascript in captivate
            Colin Holgate MVP & Adobe Community Professional
            I think here is an ok place to ask this, seeing as the solution goes into your Animate code.
            I don't really know JQuery at all, but it also seems to have a .parent() function. Would this work?:
            with:
                 var box = $(window.parent().'#restart_loop')[0];
                 window.parent.cpAPIInterface(box)
            • 3. Re: Javascript in captivate
              Well I'm asking how I make my javascript code in Adobe animate access this particular var in captivate, most of the interaction stuff that I use in animate cc to control adobe captivate variables and bits I find in this forum not the adobe captivate forum, mainly because the interactions I create are not standard out of the box stuff that captivate does, I only really use captivate ad a wrapper for animate.oam files to produce unique e-learning interactions.
              • 4. Re: Javascript in captivate
                Hi Colin, thanks will give it a go and let you know
                Kind regards
                Craig Sumner
                • 5. Re: Javascript in captivate
                  Hi Colin
                  that just broke the oam. the preview and the oam both could not display the button after I applied the code in animate cc,
                  I tried a few variations such as window.parent.cp but none of it had any effect
                  • 6. Re: Javascript in captivate
                    You could look in the browser's developer tools to see if there are any errors that would give a clue about what's going wrong.
                    Would you be able to post the page somewhere we can try it?
                    2 people found this helpful
                    • 7. Re: Javascript in captivate
                      bobbyjourdan Level 1
                      Hi Colin
                      I have been reading the post and also other similar ones but I cannot find the way to control Captivate from the Animate oam movie.
                      What would be the simplest command that I can attach to a button in Animate project that would be exported to oam.
                      In Captivate I would use this JS line to move to the next slide for instance.
                      window.cpAPIInterface.next();
                      How can I attach it to a button in Animate. I try this for instance but without success...
