2 Replies Latest reply on Feb 10, 2018 3:55 AM by Stephen_A_Marsh
    Change color for clean black channel
    MHRabbani
      I have an image (one layer tiff) with 8 solid color.
      Only one of these colors has a black layer (0,0,0,100).
      I want to change this color (0,0,0,100) to (100,100,100,0) to clean the black layer of image.
      when I use replace color tools, the texts are thinner.
      How can I change color without changing the texts thickness?
        • 1. Re: Change color for clean black channel
          D Fosse Adobe Community Professional & MVP
          You can copy>paste between color channels, so technically it's no more difficult than that. Note that 100-100-100-0 won't give you a neutral black! Inks have different densities.
          Since these are CMYK numbers I assume this is going to an offset press? You need to watch the total ink limit. If you end up with 100-100-100-100 in some areas, you have a problem. The ink will smear and not dry properly.
          Most CMYK profiles have an ink limit in the 280% - 320% range. This is built into the profile. A so-called rich black, printed on all four plates, maximizes ink on each plate to give the deepest black possible without exceeding the limit.
          • 2. Re: Change color for clean black channel
            Stephen_A_Marsh Adobe Community Professional
            As only one image has black values, you could use Apply Image to “stamp” the K data to the CMY channels, then a curve to the K channel can easily remove all K data. Channel mixer may also be an option, however a CMYK test image would be needed.
