Want some feedback re this please - was declined due to grain/noise problem. I know that there is "blur" in the background content as a result of the depth of field, but I wanted to get some input re the noise issue? Thanks!
This is a great photo except - The background does have blur, lots of objects and noise. The foreground of snow might also have grain or noise problems. Cat looks very good - some hairs on left might need sharpening. Tough one for me. Good luck. JH
Blurred image background is generally a means of creating an image, which is correct. But here you should make sure that the effect is not technically destroyed by excessive sharpening and increased noise.
Here is a section from the background of your picture:
This is what a correct blurred background in the magnification should look like:
I hope this could help you.
Greets,
v.poth
I use Topaz DeNoise6 on images where I have that problem. It works sometimes and sometimes not. I used it on your image and it looks 100% better. I am not sure if Adobe has a problem if someone is using DeNoise or not. But here ya go
Thank you for the suggestion - I will definitely check it out!!
