I am working with Acrobat Pro DC version 2018.009.20050 when I use the send file option to open a Outlook 2016 new e-mail the file attaches as expected. I then would insert a signature and address the e-mail and hit send. when I check the sent e-mail the signature and all of the text that I added has disappeared. I then check with the person that got the e-mail and there is no text in the body of the e-mail.
I have this problem on two machines one is a window 7 pro machine and the other is a windows 10 machine,
We turned off outlook cached mode and it seems to solve the issue, but slows outlooks performance for us.
Wow the very thing that helps us send email quickly now hinders our performance. What an oxymoron!
Bonjour,
J'ai aussi le même problème sur les ordinateurs de mon entreprises avec les configurations suivantes :
-Version Adobe Acrobat Reader DC 2018.011.20036
-Outlook 2016
-Windows 7 Pro et 10 Pro
Sur Acrobat reader je clique sur l'enveloppe > Envoyer le fichier > Outlook 2016 se lance avec la pièce jointe > je tape le texte dans le corps du mail > bouton envoyer sur Outlook.
Le destinataire reçoit bien le mail avec la pièce jointe, mais le corps du mail est vide.
Merci d'avance pour votre aide.
Cordialement.
Hi All,
Thank you for reporting the issue.
Could you please provide more information on this as asked below:
- Share the exact version of the application you are using to send a file as an attachment. Take help of the steps mentioned here Identify the product and its version for Acrobat and Reader DC to check the version number.
-What is the OS version installed on the system?
-Is it an issue with some particular PDFs or with all?
- Can you send us an email with the attachments? I will be sharing the email address in the private message. Please check your inbox.
- Please share the steps used to replicate the issue.
We will be waiting for your response.
Regards,
Meenakshi
Meenakshi,
Did you read the post? I said it was Acrobat Pro DC version 2018.009.20050 I also said it was windows 7 pro and windows 10 machines, this happens to all PDF sent via Adobe send mail button. Here is a PDF download showing the results of a sent email. https://optimumwindow.com/wp-content/uploads/error_adobe.pdf
Bonjour Meenakshi,
Je vous ai envoyé un mail de test, avec une pièce jointe et du texte dans le corps du mail.
Le problème est présent sur toutes les machines Windows 7 ou 10 avec Outlook 2016.
La version d'Acrobat reader est : 2018.011.20036.
Merci d'avance pour votre réponse.
Cordialement.
Most people did not like the performance hit from disabling outlook cache. We found that hitting the save button in outlook before the email is sent helps as a better work around.
Any updates on this? My users are still having this issue.
