0 Replies Latest reply on May 15, 2008 7:41 AM by crispy_cornflakes
    Object Instantiation Issue
      Greetings all on the forum.
      I have an actionscript/flash related problem that I hope someone can shed some light on.
      I have a list of button instances contained within a movie clip instance.
      Each button instance has a name with the following convention: button_product'n'
      where 'n' is an incremental value starting from 1 and increasing by 1 for each instance.
      e.g 'button_product01' ... 'button_product42' etc.
      I have a list of movie clips (off stage) each named in relation to the button
      names in the following way:
      'product01' ... 'product42' et al.
      Thus, for a button instance called: 'button_product05' there exists a movie clip with a name of: 'product05'
      With reference to the button instances: Each button instance has an onPress() event handler attached to it at runtime.
      When a user clicks on a button instance e.g 'button_product42' an instance of the corresponding movie clip
      is created and allowed to be dragged around the stage and dropped in a specific area.
      In this case the corresponding movie clip is 'product42'. Upon instantiation the movie clip instance name is appended with
      a value corresponding to its depth (1 in this case) thus 'product42' becomes: 'product42_1'.
      Each time a new movie clip is dragged onto the stage in this way the suffix is incremented.
      A typical example could be to have the following instances on stage:
      whose depths are 1, 2 and 3 respectively.
      When the instance is dropped onto the stage it is wrapped in a custom object which allows a number of values associated with the
      instance to be saved such as its name, x and y coords and depth.
      This object is then inserted into an array.
      When the user clicks 'save', the array is written to disk in the form of a shared object.
      The problem occurs when I try and re-instantiate the objects on the stage immedeately after I have saved them.
      For example, a load operation with the following data:
      A.) product05_1
      B.) product05_2
      C.) product05_3
      In the debugger list of current instances I see both A and B being created but when it comes to creating C both A and B dissapear
      from the debugger list and are replaced by C yet on the stage C is not present but both A and B are!.
      My intial reaction here is that there is an issue with respect to depth but each movie clip instance is being created
      with a depth of 1, 2 and 3 respectively.
      Now the fun - If i save the above list of objects and then restart the flash movie and try to load them i get A, B and C
      in both the debugger list of instantiated objects and on the stage ergo no problem!
      I have inspected the shared object data file and the integrity of the saved data is good in all cases.
      It seems the problem is only evident during a load operation immedeately after a save.
      Does anyone have any clue as to what the problem could be here?
      Apologies if this isn't clear - I am happy to clarify any points that I have made here.
      Thanks in advance for any help offered.
      N.B. The company I work for would be interested in employing a contract/freelance developer to fix this problem.
