hello,
i am just starting to use this after having used procreate for a while. i am having a very hard time organizing projects into folders. i am a cartoonist and i nee to compile weekly "batches." i cannot even figure out how to make projects within projects. this is similar to what procreate so easily and intuitively does in a feature they call 'stacks' -- a drag and drop way to create and name and organize projects. please help, i am working on batch for tomorrow and would love to know how to do this. there are so many features on sketch that seem good, especially the way to control pens, i would really like to use it this afternoon. thank you.
Hi Ken.
It's not possible to organize drawings into folders, but you can add new drawings to an already existing project. To do that, tap on the project you want to add a drawing to THEN tap the + icon (if you tap the + icon before choosing an existing project, that drawing will open in its own project).
You can also move drawings between projects
In the Organizer view (where you can see all your projects), tap on the project that contains the drawing you want to move.
Then tap the Ellipsis (...)
...Copy link to clipboard
Hi Ken.
Then tap the Ellipsis (...) icon
From the pop-up menu choose Select Documents. At that point the top nav will change to blue and in the lower nav you'll have three icon choices: (Trash) a garbage can, (Duplicate) two squares with a +, and (Move Document) a document with an arrow.
Tap on the drawing you want to move (it will be highlighted in blue)
Then, from the lower nav, tap the Move (document with an arrow) icon
That will bring up a menu with a choice of places to move it.
Do those things help?
Sue.
i'll try it shortly and see. thanks
