• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Book Cover page
New Here ,
May 15, 2008 May 15, 2008
In the table of contents is there a way to add a topic to the book in such a way that if i click on the book it should show that topic in wysiwyg editor.
Any suggestions.
Views
524
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Welcome to our community, rr336
Assuming RoboHelp HTML here.
If you right-click the book, you may edit the properties. There, you may click the check box labeled "Book with link" and assign a topic that will display when the book has been clicked by your end user. To edit in RoboHelp HTML easily, don't double-click the book. Instead, right-click and you will see an option to edit the topic.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Rick. So i could remove that topic from the book rite once i have linked the topic as the book cover page else the topic will be repeated. Correct me if i am wrong.
Votes
Translate
Translate
Report
Report
Advisor ,
Yes, instead of being, say, the first topic under the book, it would now be the book.
Leon
Votes
Translate
Translate
Report
Report
Explorer ,
May 16, 2008 May 16, 2008
This was my next query... with the Breadcrumbs feature in v7, when i click "up" a level it takes me to the first (alphabetically) page under that book, which is not what I want at all!
So now it seems I have to go through the whole project and create a "Summary" page for each book, linking it with the "Book with Link" option.
Or is there a clever way to do this automatically? Create a little page that just has the heading of the book and links to the topics within that book... (he says, hopefully!)
Votes
Translate
Translate
Report
Report
Advisor ,
I guess I'd look into the flat file that holds breadcrumbs (any RH7 users know which it is?) and use a good replace tool to adapt related sections of that code into a separate "book" topic. While not actually automated, this might at least save a lot WYSIWYG effort.
Leon
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Leon
I don't believe it's a file any one of us can edit. I stand to be corrected on this, but I believe it's something that is created "on the fly" or dynamically during the process of generating the output.
Then again, only the developers know for sure!
Cheers... Rick
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
Some code is inserted into each topic when generating WebHelp. It calls a function AddMasterBreadcrumbs in whthost.js.
Part of this function generates the "home" link on the fly. In a merged project, "Home" is the home page of the parent project, not the subproject.
The first link upward is "hard" coded in each topic during WebHelp generation. It is the first topic under the book in which the topic appears (alphabetical only if the Book TOC is alphabetical.) I haven't gone further than one level of books, so I don't know how it handles a book-within-a-book. My guess is, the first upward link stays within the closest book. I do not use books linked to topics, so I don't know what happens there.
I'm not clear on precidely what you're trying to accomplish, but if you don't have too many topics, you could try manually editing the output files.
If you're comfortable with search-and-replace, you can save some time. The point is, I think you can make the breadcrumbs say anything you like, after generating.
Harvey
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
