1. Re: Crop icon not there and Crop is grayed out
Peru Bob Feb 13, 2018 10:46 AM (in response to mickiea51734434)Is the correct layer selected?
2. Re: Crop icon not there and Crop is grayed out
Peru Bob Feb 13, 2018 10:46 AM (in response to mickiea51734434)Moved to the Photoshop Forum.
3. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 10:49 AM (in response to Peru Bob)I open it up and I try to crop and it wont let me....every time!!!
4. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 10:51 AM (in response to Peru Bob)no layers added. No layers to delete. Every time I open the program, it will not let me crop. I can only crop if it's a raw pic and the first window before it goes into the program, lets me crop.
5. Re: Crop icon not there and Crop is grayed out
Peru Bob Feb 13, 2018 10:53 AM (in response to mickiea51734434)Can you post a screenshot of the whole interface including the layers ppanel?
6. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 11:20 AM (in response to Peru Bob) -
7. Re: Crop icon not there and Crop is grayed out
Tanja2014 Feb 13, 2018 11:26 AM (in response to mickiea51734434)1 person found this helpfulfor that crop feature you need to make a selection first. i don´t see that you made a selection.
use the crop icon on the left toolbar instead for cropping an image without making a selection first.
if you don´t see the crop icon there you have to edit the toolbar (the three points icon)
8. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 11:28 AM (in response to Tanja2014)Thank you, but there is no crop icon, if you look. I am new with Photoshop CC, but my old photoshop had the icon. Is there a different Icon??
9. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 11:28 AM (in response to Tanja2014)Look at my first photo, there is no crop icon...
10. Re: Crop icon not there and Crop is grayed out
Tanja2014 Feb 13, 2018 11:31 AM (in response to mickiea51734434)1 person found this helpfulin your case press (longer) on the 5 icon from above and change from PERSPECTIVE CROP TOOL to CROP tool.
11. Re: Crop icon not there and Crop is grayed out
jane-e Feb 13, 2018 11:34 AM (in response to mickiea51734434) -
12. Re: Crop icon not there and Crop is grayed out
Tanja2014 Feb 13, 2018 11:35 AM (in response to jane-e)is my message invisible?
13. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 11:37 AM (in response to Tanja2014)Thank you Jane and Tanja!! I see it now. I knew it was something I was doing wrong!! It's been driving me crazy, haha. Have a joyful week. Mickie
14. Re: Crop icon not there and Crop is grayed out
jane-e Feb 13, 2018 11:37 AM (in response to jane-e) -
15. Re: Crop icon not there and Crop is grayed out
Tanja2014 Feb 13, 2018 11:38 AM (in response to jane-e)1 person found this helpfulevery time i come here i solve an issue and someone who gives the same answer 5 minutes later gets the points....
16. Re: Crop icon not there and Crop is grayed out
jane-e Feb 13, 2018 11:41 AM (in response to Tanja2014)Tanja, I unmarked mine as correct so one of yours can be marked. I don't care about points.
17. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 11:41 AM (in response to Tanja2014)switched it, you got credit!
18. Re: Crop icon not there and Crop is grayed out
Tanja2014 Feb 13, 2018 11:44 AM (in response to jane-e)1 person found this helpfuli normaly do not care either.
but this is the 20st time or so i noticed this... so i do wonder if because of my sometimes harsh critics against adobe some mods here are biased.
19. Re: Crop icon not there and Crop is grayed out
pixxxel schubser Feb 13, 2018 11:45 AM (in response to Tanja2014)the crop tool is not available in all workspaces.
Maybe this thread is only a joke.
The tool palette is not standard and there is a stacking symbol in the left corner of the control bar. The TO doesn't show us the very important Layers palette.
Perhaps this is the 3D workspace - there is no crop available.
If is not a joke:
I think the solution is to change the workspace to normal. If this doesn't work - rasterize the layer and after then try to crop again.
20. Re: Crop icon not there and Crop is grayed out
mickiea51734434 Feb 13, 2018 11:46 AM (in response to pixxxel schubser)No a joke, they solved my problem.
21. Re: Crop icon not there and Crop is grayed out
pixxxel schubser Feb 13, 2018 11:54 AM (in response to mickiea51734434)What is this for a stacking symbol in the top left corner?
And did you noticed this helpful post?
Tanja2014 wrote:
… for that crop feature you need to make a selection first. i don´t see that you made a selection.
22. Re: Crop icon not there and Crop is grayed out
jane-e Feb 13, 2018 12:06 PM (in response to Tanja2014)Tanja2014 wrote
i normally do not care either.
Tanja2014, that has to be frustrating! Sometimes a post goes into the moderation queue until a moderator approves it (which is usually quick). I wonder if that is happening to you? If you think it is, pm me.
