В российском законодательстве выделены 3 вида электронных подписей. Какому из них соответствует ЭП Adobe? Заменяет ли она собственноручную подпись и печать на документе? Документ, подписанный такой подписью, имеет юридическую силу на территории РФ? Или это подпись, скорее, для внутрикорпоративного пользования?
Hi Olga_Is,
Would you mind sharing more details on the term Adobe EP you are referring to?
In Adobe Reader / Adobe Acrobat application, you can sign a pdf using Fill & Sign and Certificate signature option or with Adobe Sign, which is a cloud-based, enterprise-class e-signature service.
Please refer to the following links for more info:
Fill and Sign: Fill and sign PDF forms using Adobe Acrobat Fill & Sign
Certificate-based signature: About certificate signatures in Adobe Acrobat , Certificate-based signatures, Adobe Acrobat
Adobe Sign: Adobe Sign FAQs
Shivam
Hi Shivam,
Thank you for your reply and clarification. I was referring to Adobe Sign, but I'm interested in any solution providing certificate-based highly-qualified e-signatures for businesses that comply with the Russian legal requirements for legally binding e-signatures.
Thank you for the links! I'll take a closer look.
Best regards,
Olga
Hi Olga,
I have sent you a private message, please check the inbox.
-Shivam
