• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Drag and Dropped files CS6 (bad alignment)
New Here ,
Feb 14, 2018 Feb 14, 2018
If I have two same pictures.
I first drag one to photoshop, and then I want to drag another one, the second picture is not aligned with the first one. It is embedded a little lower. Does anyone know how to solve this problem?
Views
541
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 15, 2018 Feb 15, 2018
Before you drag in the second photo do a Select>All, then drag in the second photo.
Then maybe the alignment will be good.
Votes
Translate
Translate
Adobe
Community Expert ,
If they are identical images, link the two layers in the Layers panel by Shift-clicking on the unhighlighted one.
Choose Edit > Auto-Align Layers...Auto...OK.
Then unlink the layers.
Votes
Translate
Translate
Report
Report
New Here ,
I know this way, but that's not the point.
I want the photo immediately after the drag was well fitted, and did not go down below the working area.
Votes
Translate
Translate
Report
Report
Community Expert ,
What version of Photoshop are you using?
Are the two pictures the same exact same size and resolution?
Votes
Translate
Translate
Report
Report
New Here ,
Yes, these are exactly the same pictures called from one raw(cr2).I'm using photoshop cs6
Votes
Translate
Translate
Report
Report
Enthusiast ,
Try holding SHIFT while dragging
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Pawelj,
If you have them both open in Photoshop, you can use "shift" to drag and drop it in. You can also use the Duplicate Layer function.
Hope you find this helpful,
-Sebastian
Votes
Translate
Translate
Report
Report
Community Expert ,
I think that dragging is the same as 'Place'.  I was going to suggest that you made sure Resize images During Place and perhaps also Always Create Smart Objects when Placing were turned on in Preferences > General, but your screen shot seems to indicate that they are already turned on.
That has me wondering because my images are always aligned centrally when I place or drag them.
Is the Canvas size the same as the image(s) you are dragging?  If not, does it have the same aspect ratio?  I have a feeling that might not be the case.
Votes
Translate
Translate
Report
Report
New Here ,
The photos are indentical because they come from one cr2 file.
Unfortunately, holding the shift button does not work. Similarly, the options you have indicated. Maybe it's a program error?
Przechwytywanie.PNGThey differ only in the exposition.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
thank you very much. It works!
Votes
Translate
Translate
Report
Report
