• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Wrapping Text in Photoshop CC
Explorer ,
Feb 14, 2018 Feb 14, 2018
Hi, I'm trying to wrap text around a shape in photoshop CC.
I have created a layer with the letter J in it.
I want to wrap text around the J so that the background is filled and the J is blank. I have tried selecting the area around the J, creating a work path, then going to paths, selecting that work path and then pasting my text into it. The text fills the work path, but goes in front of the J and doesn't wrap around it. It seems to create it's own work path.
I have watched dozens of videos and read loads of posts, but still can't work out what I'm doing wrong!
Views
23.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
I don't think what you want to do is possible. PS can't wrap text around a hole, which is what you're trying to do with the J. I think the best you can do is to split the J along with the text box (as a path) into two parts and then fill with your text and align the lines. With word wrap, it really doesn't look all that good.
Votes
Translate
Translate
Report
Report
Community Expert ,
As Chuck said, Photoshop does not have a text wrap feature.
The workaround is to create a rectangle path using the Rectangle tool. In the Options bar, select Path.
In the Options bar, select Subtract.
Draw a J shape. It must intersect the rectangle. The two vertical lines at the top of the J could touch. I drew them with space in between so that you could see how they are intersecting. You will probably want to draw the J a little larger than the separate layer that contains the J so that the smaller text doesn't touch the J.
Then select the Type tool and click inside the rectangle. The Type tool should have a circle around it when your cursor is within the rectangle. Then click and start typing.
Put the large J on a separate layer.
Votes
Translate
Translate
Report
Report
Community Expert ,
As you'll worked out, Photoshop is not ideal for page creation.  This would be trivial to do in InDesign or Publisher, which not many people have installed, but something a lot of people do have on their computer is Microsoft Word.  Word can't do the sort of fine control that InDesign can do, but it is straight forward and might be good enough.
  • You need to make your letter J the right sort of size, and save it from Photoshop as a PNG file with the background layer turned off.  This gives you the transparency.
  • Open Word and insert your letter J PNG file.
  • Click on the image and then the Text Wrapping options, and choose Tight.  You'll then be able to position the J
  • Click on the wrapping options again, and then See More at the bottom, and select the Text Wrapping Tab
  • Make sure it is set to Both sides and set the clearance to zero on the left, and a minimal distance on the right.
  • Start typing.  It is a bit clunky, and does not fill the hollow as you can see below, but you might find it easier than messing with Shapes and paths in Photoshop.  You do, of course, need to have Word, and if you have Office installed, you might have Publisher [spit].
[EDIT]  Word can also do full justification.  (So can Photoshop from the Paragraph panel, but I am not so sure it would manage that alignment on the left edge of the J, and that is making things look nice and tidy).
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 15, 2018 Feb 15, 2018
Hi guys,
Thank you for your input. Very helpful indeed.
I do actually have indesign loaded and do use it occasionally. I'm not very familiar with it, but I think it's time to look at that as my solution!
Votes
Translate
Translate
Report
Report
Community Expert ,
Wow!  InDesign is quite addictive, and a total no brainer when it comes to page layout beyond working out web page layouts.  If your document has more than page, then it would be crazy to use Photoshop if you have the choice.  I'm sure Steve and the guys on the InDesign forum are as helpful as we 'try' to be.
Learn how to wrap text around objects in InDesign
Votes
Translate
Translate
Report
Report
Community Expert ,
It’s a piece of cake in InDesig. Even illustrato it’s preyy easy.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 08, 2020 Aug 08, 2020
LATEST
Not only wrap text around an image but also fit the text to ANY shape using this super easy technique in Photoshop! In this tutorial, learn how to use the pen tool and guides to create custom shapes which act like text placeholders, and make the text fit into those boundaries. Also, we will touch
Votes
Translate
Translate
Report
Report
