MSI Titan GT80 SLI
OR.......
CPU is most important. Turbo speed of 4th generatio (older processor) is less than GL72M, i7-7700HQ. The i7-770HQ is currently the fastest laptop CPU
Faster DDR4 memory might another plus factor
Larger screen is a plus for me but I guess I could put up with the 17-inch
Lousy 1 TB 5400 rpm drive in GL72 should immediately removed and replace by SATA III SSD.
GT80 is a dual GTX 970M in SLI this SLI connection is not supported with Adob and might cause problems
I would suggest you go with the GL72 M but try to find a model with a GTX 1060 6GB GPU
I am trying to look for a gaming laptop/ work laptop max $1000.00
Any suggestions?
Take a look at this Factory Refurbished Dell. The only question you should ask before buying is "What model is the nVidia graphics card? I am guessing it is a GTX 1060 as they do say it is nVidia and 6 GB.
It has a SSD with OS and Apps but then a lousy 1 TB 5400rpm drive. To get around this either replace it with a SATA III SSD or you can use a Samsung T3 or T5 which is a very edit friendly portable USB 3 SSD.
