Expand my Community achievements bar.
Join us for the next Community Q&A Coffee Break on Tuesday April 23, 2024 with Eric Matisoff, Principal Evangelist, Analytics & Data Science, who will join us to discuss all the big news and announcements from Summit 2024!
SOLVED
Download File Name Report has more data than expected
Avatar
Level 4
Hello All,
We have getting data for "Download File Name Report" on our production site but we see predominant data has been fired for particular four days (From Jan 25th to Jan 28th ) on Jan 2018. When I debug now I see the data is firing perfectly and looks average for Feb 2018.
We were using prop 13 and evar 13 to see the Download File Name Report.
What might have caused to get this much of data for this particular 4 days? can anyone help on this issue please. Please let me know for any other information.
Thank you,
Jay.
1 Accepted Solution
Avatar
Correct answer by
Level 5
Dear Jay,
If you have the access to Data Warehouse from Adobe Analytics then your Job is simple. Select the period where you got the predominant data and choose the Granularity as "Hourly" then select the custom variables eVar or Props from the item category.
Followed by "IP" from the same Breakdown standard column. Finally choose the metrics (Instance) or any other custom metrics that you have assigned for the PDF tracking. Send the file/report to your email ID as .csv format and see how many PDF hits or downloads happened on the particular IP.
Note: I hope there is no other way to see the IP details apart from Data Warehouse or Data Workbench (Adobe Insights).
Hope this helps!
Vijay
View solution in original post
Avatar
Level 5
See if you can do something like a contribution analysis. There is a built-in tool.
You could also look to see if you can manually find the source of the anomaly. Were the anomalous downloads all from one specific geographic region? Did they all use the same browser or have the same ISP? Did they all have the same last touch channel or referrer?
Avatar
Level 3
There can be a lot of different reasons for this kind of spike or unusual behavior. First, you can look at referrer report to see what traffic source is driving the downloads or was there some marketing campaign active that contributed to this?
You can also use segment PDF download > exists ( in case you get unspecified data)
If you capture visitor ID or unique ID's, you can breakdown to see whether was it some kind of bot (if multiple hits are coming from one ID) that can also lead with some helpful information.
Avatar
Level 4
Thanks for your reply, I see referrer type is only "typed/bookmarked" and we don't see any campaign for those particular days.
also, there is no unspecified data on the report.
How can we see the IP's particularly which comes? please let me know the way
nikitarama​ this is for your question as well.
Avatar
Correct answer by
Level 5
Dear Jay,
Hope this helps!
Vijay
Avatar
Level 5
If you don't have access to Data Warehouse, and you also do not capture the IP address as an s.prop or something, you could try to narrow it down by other information about their technology.
Does the majority of these downloads come from a single ISP? This would be the Domain dimension. Are they all using a specific version of a browser or operating system? If it's all coming from a single domain and a single version of a browser I'd be suspicious.
You could also look at the Visit Depth and/or Hit Depth for these downloads. This would show you if these downloads came from visits that just navigated to a page and downloaded or if there was some organic browsing activity. If all the downloads came at the same visit or hit depth I'd be suspicious.
Avatar
Level 4
wonderful, I got the IP's. Thanks a lot for your guidance.
