4 Replies Latest reply on May 14, 2008 10:24 PM by Newsgroup_User
    Problem exporting slices
    choirellie
      This issue only started occurring yesterday and only in some cases. Therefore, I'm guessing I inadvertently changed some setting that is causing the problem. Here's what the problem is:
      I create a slice in my FW document/design. Let's say the dimensions of the slice are 200x400pixels. Then I export the slice by right clicking on it and selecting "Export Selected Slice". I save it to where I want it go.
      Then when I open the jpeg or gif I just created in another program (Dreamweaver or a browser), the dimensions are completely changed perhaps 51x67 pixels.
      I have gone through many different settings and compared against FW files where this is not happening and I can not figure it out.
      Has anyone run across this and/or know how to reset whatever might be the cause?
      Many thanks!
        • 1. Re: Problem exporting slices
          JoeDaSilva Level 4
          Could be your resolution perhaps. Open a PNG and then head to Modify > Canvas > Image Size. Towards the bottom of the prompt, check to make sure the resolution is set to 72 DPI.
          • 2. Re: Problem exporting slices
            Level 7
            > pixels.
            > cause?
            > Many thanks!
            Go to File > Image Preview and make sure the export size is set to 100%
            Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
            http://www.communityMX.com/
            CommunityMX - Free Resources:
            http://www.communitymx.com/free.cfm
            .:Adobe Community Expert for Fireworks:.
            http://tinyurl.com/2a7dyp
            See my work on Flickr
            http://www.flickr.com/photos/jim_babbage/
            • 3. Re: Problem exporting slices
              choirellie Level 1
              Thanks Jim! That was the problem. I'll be sure to check that going forward. I'm not sure why it suddenly starting defaulting to something other than 100%, but glad to know what was causing this!
              • 4. Re: Problem exporting slices
                Level 7
                You're welcome. FW remembers the settings the last time an object was
                scaled in the Image Preview window and then saved. Also, keep in mind
                that multi-page documents can have their own scaling on a page by page
                basis, so make sure to check your pages as well if you're using that
                feature.
