• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
3
Nvidia OpenGL Driver crash on startup
Community Beginner ,
Feb 20, 2018 Feb 20, 2018
Hi, I am having a really annoying issue with Premiere Pro CC 2018.
Ever since the latest Windows 10 Creators Update Premiere consistently causes the Nvidia OpenGL Driver to crash upon loading a project. Specifically, it crashes once Premiere tries to load the first videoclip into the preview monitor. Opening JUST the program works fine.
Windows gives these error reports (sorry, they are in German):
Quelle
Adobe Premiere Pro CC 2018
Zusammenfassung
Nicht mehr funktionsfähig
Datum
‎20.‎02.‎2018 16:44
Status
Der Bericht wurde gesendet.
Beschreibung
Pfad der fehlerhaften Anwendung: C:\Program Files\Adobe\Adobe Premiere Pro CC 2018\Adobe Premiere Pro.exe
Problemsignatur
Problemereignisame: BEX64
Anwendungsname: Adobe Premiere Pro.exe
Anwendungsversion: 12.0.1.69
Anwendungszeitstempel: 5a4defd6
Fehlermodulname: nvoglv64.dll
Fehlermodulversion: 23.21.13.9077
Fehlermodulzeitstempel: 5a67b485
Ausnahmeoffset: 0000000000fde979
Ausnahmecode: c0000409
Ausnahmedaten: 0000000000000007
Betriebsystemversion: 10.0.16299.2.0.0.768.101
Gebietsschema-ID: 3079
Zusatzinformation 1: 7a26
Zusatzinformation 2: 7a26cd0dd2f7883f2e807cfd8dcb829c
Zusatzinformation 3: 5e40
Zusatzinformation 4: 5e400ab0022931b1faaca398e3eb9b37
Weitere Informationen über das Problem
Bucket-ID: 381734f7dec2a3b7b000a7843b520698 (1153105690979600024)
Unable to recover from a kernel exception. The application must close.
Error code: 3 (subcode 2)
(pid=4740 tid=2144 adobe premiere pro.exe 64bit)
I am using a Quadro M4000 with the latest ODE-Driver 390.77.
Funny enough, if I open Premiere right after booting my machine, it usually opens fine and I can work with it for as long as I want without any errors. Only when I open other programs like my browser or my mail client, sometimes even just browsing folders, causes Premiere to crash the OpenGL driver upon launching later on.
I already talked to a Nvidia support member, they made me try different power settings on my machine and in the Nvidia Control panel, but that didn't change anything. So they told me to report this problem here as well to see if there are any known issues or solutions to that problem.
Some ideas what's happening here? Thanks in advance!
Views
31.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Mar 19, 2018 Mar 19, 2018
You can find it in the NVIDIA Control panel, this is in italian but i hope you can understand where it is:
and, yes, with this setting seems there is no more OpenGL error.
Alex
Votes
Translate
Translate
Feb 24, 2018 Feb 24, 2018
the same happens to me with Premiere and Aftereffects
Votes
Translate
Translate
Report
Report
New Here ,
Feb 26, 2018 Feb 26, 2018
same here.
where the hell is the Adobe chat?
Votes
Translate
Translate
Report
Report
Nov 06, 2018 Nov 06, 2018
Me too, and I updated everything to the latest versions: the OS, the Nvidia drivers (Quadro M4000 v. 416.30), and the Premiere PRO to 13.01. Everything is OK until I create or open a sequence (I use DNxHD type). That's when I get NVIDIA OpenGL Driver error code: 3 (subcode 2).
Votes
Translate
Translate
Report
Report
Using Lomarx's suggestion, changing Manage 3d Settings from Base Profile to 3D App-Visual Simulation on the Global Settings tab in the NVIDIA Control Panel fixed this for me too (at least for now). Thank you!
Votes
Translate
Translate
Report
Report
LEGEND ,
One thing you might try is language consistency.  Install English version of Adobe software only on an English version of Windows.  Install German Adobe software on German Windows.
Votes
Translate
Translate
Report
Report
Feb 25, 2018 Feb 25, 2018
Our Windows are installed in Spanish and Premiere too. Additionally, we have four Windows and Premiere in english.
Everyone has that problem
Votes
Translate
Translate
Report
Report
LEGEND ,
The posted image shows mixed languages.  Something is non-standard there.
Votes
Translate
Translate
Report
Report
My Windows 10 is set up in German, also Premiere is running in German. Only the error message is in English and that is something i can not influence. I highly doubt that this is a language consistency problem, since other people who are running everything in Egnlish are having the same issue.
Also a user from Nvidia tech forum suggested to use a special preset in Nvidia Control Panel, namely "3D App Visual Simulation". From his experience using the standard profile or anything else caused the crash, while this preset seems to work fine. I tested it and it also solves the issue on my machine.
So probably the error is caused by some feature, that is disabled or not used with this certain preset. Nvidia dev team hasn't yet come up with a reply, only that they are looking into it.
By the way, you probably only get these presets in Nvidia Control Panel when you are using a Quadro Card, I THINK GeForce Cards don't offer those.
Maybe this helps someone.
Votes
Translate
Translate
Report
Report
Mar 13, 2019 Mar 13, 2019
Thanks a lot! I personally had a Quadro M1000 this error occurred and only the video editing preset worked. Now I am using Premiere on HP Quadro M1200 and the same happened. Now video editing didn't work so I thought I couldn't fix it. Until you came along and told about visual simulation. You saved my day. or week.
Votes
Translate
Translate
Report
Report
So my guess would be, at least Quadros are really vulnerable for this issue. And apparently also the titan 1080. We should see what is the real issue. Than visual simulation would be turned off and only premiere settings in NVidia contol panel could be changed. Personally I would prefer that.
Votes
Translate
Translate
Report
Report
Contributor ,
You may try to restore your system to a point when you clearly remember that everything was ok. Save all the files you need then restore Your Windows.
Votes
Translate
Translate
Report
Report
Our Windows and PC are completely new, we can't restore anything
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 27, 2018 Feb 27, 2018
I have a Quadro M2000, English versions of everything, and all the updates (Windows, Adobe).  I have upgraded from Nvidia driver version 390.65 to 390.77 and I am having the same problem.
On the positive side, I have noticed a much lower CPU utilisation when playing back video files using the default Windows player.  So, perhaps, there are some performance improvements in the driver, but some bugs at the same time.
Could someone from Adobe try to push Nvidia for a fix.  The bug is very easy to reproduce as described in this thread.
Votes
Translate
Translate
Report
Report
Engaged ,
Mar 01, 2018 Mar 01, 2018
Same issue here with a Quadro K2200 and Nvidia driver version 390.77.
At the end of the day yesterday video playback in the preview window slowed to a crawl while the audio continued on at normal speed. I closed Premiere and reopened, and have had the above error message every time since.  Haven't been able to do my work all day long.
Votes
Translate
Translate
Report
Report
Engaged ,
Something useful:  I followed the advice of "birdy" in the post here https://devtalk.nvidia.com/default/topic/1029897/quadro-display-driver-nvlddmkm-stopped-responding-w...  and was immediately up and editing again.  Hope this helps someone else as well.
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 05, 2018 Mar 05, 2018
I have some positive news: I have just installed driver version 391.03 (23.21.13.9103), and so far it seems that this issue has disappeared.
/Karol
Votes
Translate
Translate
Report
Report
Unfortunately not for me. I'll try to reinstall with clean installation option.
I'll let you know
Alex
Votes
Translate
Translate
Report
Report
Mar 07, 2018 Mar 07, 2018
It seems now, with new driver, works well after 2 days of work with Premiere Aftereffects and Photoshop
Thank you
Alex
Votes
Translate
Translate
Report
Report
New Here ,
Im with the P4000 Driver:390.77 and after 3 days needed to install again the driver.
Votes
Translate
Translate
Report
Report
Have you tried the latest driver (391.03) ?
Votes
Translate
Translate
Report
Report
Mar 08, 2018 Mar 08, 2018
Yep, just got the error even with Driver Version 391.03
As before, the profile "Visual Simulation" works fine, everything else causes the open GL error.
greets, Dominik
Votes
Translate
Translate
Report
Report
Today, when I close Premiere, got the error with 391.03
Now I'll try "Visual Simulation" profile and pray...
Thank you
Alex
Votes
Translate
Translate
Report
Report
New Here ,
Mar 13, 2018 Mar 13, 2018
Today when switching between youtube and premiere i got the error with 391.03.
What is the visual simulation that you talking about?
Best.
Votes
Translate
Translate
Report
Report
Alex
Votes
Translate
Translate
Report
Report
