8 Replies Latest reply on Feb 25, 2018 5:29 AM by ia89823338
    Create a txt file in Extendscript
    ia89823338 Level 1
      Hey!
      im trying to create a script that creates a txt file but i can't do that...
      that is the function code:
      var scriptFolderPath = File($.fileName).path; // the URI of the folder that contains the script file
      var TimerFolderPath = scriptFolderPath + encodeURI("/ProjectTimers_sources"); // the URI of the folder for your script resources
      StartButton.onClick = function(){
      var JFile = new File(TimerFolderPath + encodeURI("/File.txt"));
      var content="That is a text file";
      File.write(content);
      alert("File created!");
      and it doesn't creates any file...
        • 1. Re: Create a txt file in Extendscript
          Mathias Moehl Adobe Community Professional
          JFile.write(content);
          instead of
          • 2. Re: Create a txt file in Extendscript
            ia89823338 Level 1
            haha...
            didn't see that.
            but, the file is not being created yet...
            • 3. Re: Create a txt file in Extendscript
              Tomas Sinkunas Adobe Community Professional
              Give this one a shot.
              First you better check if you have permissions to Write Files and Access Network.
              Next, you probably need to open fine before writing to it.
              StartButton.onClick = function() {
                  var content = "That is a text file";
                  if (!canWriteFiles()) return null;
                  writeFile(JFile, content);
                  // File.write(content);
              function writeFile(fileObj, fileContent, encoding) {
                  encoding = encoding || "utf-8";
                  fileObj = (fileObj instanceof File) ? fileObj : new File(fileObj);
                  var parentFolder = fileObj.parent;
                  if (!parentFolder.exists && !parentFolder.create())
                      throw new Error("Cannot create file in path " + fileObj.fsName);
                  fileObj.encoding = encoding;
                  fileObj.open("w");
                  fileObj.write(fileContent);
                  fileObj.close();
                  return fileObj;
              function canWriteFiles() {
                  if (isSecurityPrefSet()) return true;
                  alert(script.name + " requires access to write files.\n" +
                      "Go to the \"General\" panel of the application preferences and make sure " +
                      "\"Allow Scripts to Write Files and Access Network\" is checked.");
                  app.executeCommand(2359);
                  return isSecurityPrefSet();
                  function isSecurityPrefSet() {
                      return app.preferences.getPrefAsLong(
                          "Main Pref Section",
                          "Pref_SCRIPTING_FILE_NETWORK_SECURITY"
                      ) === 1;
              • 4. Re: Create a txt file in Extendscript
                ia89823338 Level 1
                It is working!
                thanks
                i have another question.
                i want to create an if statement that checks if the file already exists. how can i do that?
                for example:
                if(***the text file we have created exists***) {
                bla bla
                • 5. Re: Create a txt file in Extendscript
                  if (File("pathToFile.extension").exists) {
                      // file exists
                  • 6. Re: Create a txt file in Extendscript
                    ia89823338 Level 1
                    Not working...
                    var p=app.project;
                    var projTLayersFound=[];
                    var projTextName = "this project";
                    //get project name:
                    var projName = p.file.name.replace(/%20/g, "");
                    var didNotFindOne = true;
                    ///Other
                    if (File(TimerFolderPath + encodeURI("/" + projName + ".txt")).exist) {
                    alert("if");
                      } else {
                        var TimerFile = new File(TimerFolderPath + encodeURI("/" + projName + ".txt"));
                        writeFile(TimerFile, content);
                      alert(projName);
                    • 7. Re: Create a txt file in Extendscript
                      Apologies, I had a typo in code: it should have been File().exists and not File().exist
                      • 8. Re: Create a txt file in Extendscript
                        ia89823338 Level 1
                        Worked! thanks
