6 Replies Latest reply on May 19, 2008 10:32 AM by edb00
    Play Flash
    edb00
      Director MX 2004 project running in a MIAW
      Contains a Flash animation -- sprite 6
      Button with this script fails with DPE.
      sprite(6).play()
      Animation plays fine the first time but won't repeat due to the DPE on the repeat button.
      Works fine in authoring Mac OSX
      ideas?
        • 1. Re: Play Flash
          Level 7
          "edb00" <webforumsuser@macromedia.com> posted in
          macromedia.director.lingo:
          > sprite(6).play()
          > the
          > repeat button.
          DPE?
          You may have to sprite(6).rewind() first.
          Mark A. Boyd
          Keep-On-Learnin' :)
          • 2. Re: Play Flash
            edb00 Level 1
            DPE Director Player Error
            Handler not found
            #Play
            Script Error Continure
            The mystery to me is why it works in authoring but not in playback.
            • 3. Re: Play Flash
              Level 7
              That is almost always due to not including the correct xtra (or the
              correct version of the xtra) with the projector.
              • 4. Re: Play Flash
                edb00 Level 1
                The animation does run the when the frame is opened. So I don't see how it could be a missing xtra.
                Its that the button to replay the animation causes the DPE.
                I'm wondering now if Director is confused by things being in a MIAW. As if the play command is being sent to sprite 6 of the main window and not sprite 6 of the MIAW
                • 5. Re: Play Flash
                  Level 7
                  The you can use the tell command to send it to the window:
                  tell window("windowName") to sprite(6).play()
                  • 6. Re: Play Flash
                    edb00 Level 1
                    Problem was customer complaining about the wrong file.
                    Everything is/was OK
