4 Replies Latest reply on May 21, 2008 9:24 PM by P Krishna
    RoboHelp CHM - Text Selection
    P Krishna
      Hi Forum,
      I am using RoboHelp X5. I want to know following:
      1. Is it possible to disable the selection of
      text/screens in the output CHM file so that they
      cannot be copied and pasted by anyone. If a script is
      involved where to place that script?
      2. In our company we connect the help file to D2K (Developer 2000)
      interfaces. In the interface when F1 key is pressed
      the help file is shown. But when the help file is
      minimized the user is not able to see the screen
      interface and only when the CHM is closed the
      interface is visible. How to overcome this and view
      both screen interface and the help file
      simultaneously.
      Give your suggestions please.
      With thanks and regards,
      Krishna
        • 1. Re: RoboHelp CHM - Text Selection
          Pete Lees Level 2
          Hi, Krishna,
          > disable the selection of text/screens in the output CHM file so that they
          See this page for some examples of scripts that you might use:
          http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=3262133&SiteID=1
          You can put these scripts in the HEAD section of each topic, or add them to a global JavaScript (.js) file to which all the topics are linked.
          > In our company we connect the help file to D2K (Developer 2000) interfaces. In the
          > interface when F1 key is pressed the help file is shown. But when the help file is
          > minimized the user is not able to see the screen interface and only when the CHM
          > is closed the interface is visible.
          Can you clarify what happens to the application interface when the user minimizes the help window? Is the interface minimized as well?
          Can you supply an example of the application code that is used to open the help file when the user presses F1? This may help us to suggest a workaround.
          Pete
          • 2. Re: RoboHelp CHM - Text Selection
            P Krishna Level 1
            Hi Lees,
            Thanks for the info you have provided.
            I am able to now block the user from selecting a text.
            I tried to use the another script available in the link that blocks the mouse menu (through which user can print/view source) but that script is not executing properly for me. Since I am not a technical guy I am not able to locate where the problem is. If you can help please throw some light on it. I want to know,
            How the function inside the nomenu.js file is called and how to pass the event to that function?
            Otherwise things are ok Pete.
            Reg viewing the interface and help file simultaneously: When the help file is invoked by pressing F1 it shows up. But when the help file is minimized normally we expect the screen interface to appear in its full. But what happens is the interface is still there (no, it is not minimized) but no contents of it are visible and it shows full grey colour.
            Krishna
            • 3. Re: RoboHelp CHM - Text Selection
              Pete Lees Level 2
              > that function?
              The function is executed when the user clicks the topic pane, because of the following lines in the nomenu.js file:
              document.onmousedown=right;
              if (document.layers) { window.captureEvents(Event.MOUSEDOWN); }
              window.onmousedown=right;
              When the user clicks the topic pane — "document.onmousedown" — the "right" function is executed. This function determines which of the mouse buttons was pressed and then, if it was the centre or right button — "(event.button == 2 || event.button == 3)" — displays the "Function Prohibited" message box.
              If it's any help to you, I can send you a sample file that illustrates this technique. Click my user name at the left to contact me by email.
              This sounds like a problem with the way the developers have connected your help file to their application. Perhaps they will find a solution in the following sites, which provide information for developers on how to implement HTML Help:
              Microsoft's HTML Help API Reference
              MS Help Wiki
              Pete
              • 4. Re: RoboHelp CHM - Text Selection
                P Krishna Level 1
                Hi Pete,
                Thanks for the details.
                The links you have given will be useful for me.
                Also, I have posted a new message regarding disbaling menu option in the navigation pane. Please look into it and give your suggestions.
                Krishna
