7 Replies Latest reply on Feb 25, 2018 3:09 PM by try67
    Page Numbers with Spawn Pages
    sebastianb99835257 Level 1
      Hello,
      I have a 1 page PDF form which I have set to be a template. I have added in page numbers up in the top right of the header (page 1 of n). I have also added a button that when pressed will execute the following code:
      var t = this.getTemplate("Template");
      t.spawn(event.target.page + 1, true, false);
      The problem is when the button to duplicate the pages is pressed the page numbering remains "Page 1 of 1" on both of the pages.
      Is there some code I can add to the button that will tell the page numbering to update after I have added the button is pressed and the new page added?
      Cheers,
      Seb.
        • 1. Re: Page Numbers with Spawn Pages
          You'll need to use fields for that.
          They can have the following calculation script:
          event.value = "Page " + (event.target.page+1) + " of " + this.numPages;
          And after spawning the pages call the calculateNow method to update them.
          • 2. Re: Page Numbers with Spawn Pages
            Hi Try,
            That's worked quite nicely. It actually works now and also looks identical to the header after I made the field read only so that's good.
            Just wondering what the point of the calculateNow method was as it currently works without using this bit of code.
            Thanks mate.
            • 3. Re: Page Numbers with Spawn Pages
              I was not sure if the spawning command will cause the calculation events to
              trigger, so I thought it's better to force it, to make sure they present
              the correct value.
              If you see it's not needed you can remove it, of course.
              On 22 February 2018 at 00:52, sebastianb99835257 <forums_noreply@adobe.com>
              • 4. Re: Page Numbers with Spawn Pages
                Hi Try,
                I have another related question to spawn pages.
                When spawning pages all of my field names now have "P4.Template." in front of them.
                This means that some of my JavaScript doesn't work, such as:
                var Zoomz = getField("Zoom_In_3");
                Is there a way to for example set n = to the total number of pages minus 1. Then change my bit of code to be something like:
                var Zoomz = getField("P"n".Template.Zoom_In_3");
                Cheers,
                Seb.
                • 5. Re: Page Numbers with Spawn Pages
                  No. The name of the spawned fields is determined by the template name, the page number and the original field name.
                  So it's predictable, but it's not changeable. You will need to modify your code to work with it.
                  • 6. Re: Page Numbers with Spawn Pages
                    I understand the way in which the template pages and fields are generated and that it's not changeable. I was basically asking if there is a way to set a dynamic variable (in this case what the page number is) and then reference it within the getField(...).
                    For example this is the hard coded field name:
                    var Zoomz = getField("P4.Template.Zoom_In_3");
                    I want to set the number in the P4 to be a variable and then reference the field that way. I'm just not sure how to use variables inside field names..
                    Something like this but I'm not sure of proper syntax or if this is even possible:
                    var Count = this.numPages;
                    var Zoomz = getField("P"Count".Template.Zoom_In_3");
                    • 7. Re: Page Numbers with Spawn Pages
                      Ah, sure, that's possible like this:
                      "P"+Count+".Template.Zoom_In_3"
                      The plus-operator can be used to concatenate strings, including the values of variables, one to each other.
