I am having trouble navigating with a project that I regenerated from an old project for the benefit of the Chrome TOC showing on the left. Now I have the problem of the lack of navigation via the URL. When I change the URL it does not change the content of the window as shown below:
Navigating to "Affected By MU" in the URL does not yield the expected result of having the page showing with that title. Navigating via the browser address field does not affect the page as it did in the old project before I regenerated it. How do I recreate this functionality?
Any help will be greatly appreciated.
Thank you,
Preston
Perhaps try clearing the browser cache? Also, if you are able, delete the output files from the server and upload fresh?
I have tried clearing the cache and I regenerated the files to the server several times.
Sooo, in your image:
It would appear you are using WebHelp. And it also appears that the link is pointing to a bookmark? I say that because of the pound or hash symbol after the PRS.htm.
How exactly are you changing the URL? Manually typing it? A hyperlink of some sort?
That link in the address bar seems quite odd. Based on the #<id=0, I'm guessing it may be a CSH call?
Cheers... Rick
Thank you, I just figured it out right before I saw your post. I removed the "#<id=0" at the end and it navigates to the correct page. For some reason this was in logic when the hyperlink is pressed that id is attached to the end of the URL.
Thank you
