1 Reply Latest reply on Feb 22, 2018 12:07 PM by alank99101739
    How to export video from Premiere Pro to Character Animator?
    John2203
      Hello everyone! I have one problem with importing video files in Character Animator, I searched on the internet but couldn't find the answer and I hope you can help me. The problem is that I don't know how should I export file from Premiere Pro or After Effects to Character Animator. The file I'm trying to export from Premiere Pro is just one minute of my screen recording. The best I was able to do is export as PNG file (and then I would get 2000 images that takes 1GB) and import it in Character Animator but then I wouldn't be able to control the video. For example When I press pause or I place the video to start from 30. seconds it would just start from the begining and it wouldn't react to pause or any other command. I know that I can make it reversed and import the puppet to premiere pro but then I'm not able to synchronize puppet's movement with the screen recording. Hope someone can help me. Cheers
        • 1. Re: How to export video from Premiere Pro to Character Animator?
          alank99101739 Level 4
          I don’t think you can import videos into character animator. Normally you use After Effects or Premier Pro if you want to edit video. Character animator can generate videos (I export H.264 or Quicktime/GoPro Cineform with alpha if I need transparency) or you can use dynamic linking to bring things across into AE or PR.  But I don’t think there is a way to get a video in the background using Character Animator.
