0 Replies Latest reply on Feb 22, 2018 5:26 PM by benr48764503
    Ajax not working in Phonegap
    benr48764503
      Hello,
      I have been for hours on this problem and cannot find the solution.
      I am trying to initiate a simple ajax call when the submit button is clicked, when I click at the moment, nothing happens, no ajax calls/responses.
      Does anyone spot my mistake please?
      Here is my code:
      In the head I have this:
      <head>
        <meta charset="utf-8">
        <meta http-equiv="Content-Security-Policy" content="default-src * 'self' 'unsafe-inline' 'unsafe-eval' data: gap: content:">
        <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no, minimal-ui, viewport-fit=cover">
      The html:
                     <form id="form-items">
                          <div class="list">
                            <ul>
                              <li class="item-content item-input">
                                <div class="item-inner">
                                  <div class="item-input-wrap">
                                    <input type="text" name="username" placeholder="Username" id="username">
                                    <span class="input-clear-button"></span>
                                  </div>
                                </div>
                              </li>
                                    <input type="password" name="password" placeholder="Password" id="password">
                                  </div>
                                </div>
                              </li>
                            </ul>
                          </div>
                          <div class="list">
                            <ul>
                              <li>
                                <button type="button" class="col button button-big button-raised button-fill button-green signIn">Sign In</button>
                              </li>
                            </ul>
                            <div class="block-footer">
                              <a href="/login/" class="text-align-left md color-indigo">Forgot Password</a> -
                              <a href="/register/" class="text-align-right md color-indigo">Register</a>
                            </div>
                          </div>
                        </form>
      The ajax
      document.addEventListener("deviceready", onDeviceReady, false);
            function onDeviceReady() {
      $('.signIn').click(function(e)  {
      alert("hello!");   // test
      e.preventDefault();
      var usernameInput = $('#username').val();
      var passwordInput = $('#password').val();
      $.ajax({
        url: serverUrl + '/api/login',
        method: 'POST',
        data: {
          'username': usernameInput,
          'password': passwordInput,
          'client_id': clientId,
          'client_secret': clientSecret
        dataType: "json",
        beforeSend: function () {
          app.dialog.progress('Connecting....');
        statusCode: {
          //If status is 200
          200: function (response) {
       //code here
            }, function (error) {
              console.log('transaction error: ' + error.message);
            }, function () {
              console.log('transaction ok');
              app.dialog.close();
              app.router.navigate('/createreport/');
          401: function (response) { //Unauthenticated
            app.dialog.close();
            console.log("error 401 Unauthenticated");
            app.router.navigate('/');
          500: function (response) { //error
            app.dialog.close();
            console.log("error 500");
          404: function (response) { //Not found
            app.dialog.close();
            console.log("error 404 Not found");
      In my config.xml I have this:
      <access origin="*" />
          <allow-intent href="http://*/*" />
          <allow-intent href="https://*/*" />
          <allow-intent href="tel:*" />
          <allow-intent href="sms:*" />
          <allow-intent href="mailto:*" />
          <allow-intent href="geo:*" />
          <platform name="android">
              <allow-intent href="market:*" />
          </platform>
          <platform name="ios">
              <allow-intent href="itms:*" />
              <allow-intent href="itms-apps:*" />
          </platform>
          <plugin name="cordova-sqlite-evcore-extbuild-free" spec="^0.9.2" />
          <plugin name="cordova-plugin-battery-status" spec="~1.1.1" />
          <plugin name="cordova-plugin-camera" spec="~2.1.1" />
          <plugin name="cordova-plugin-media-capture" spec="~1.2.0" />
          <plugin name="cordova-plugin-console" spec="~1.0.2" />
          <plugin name="cordova-plugin-contacts" spec="~2.0.1" />
          <plugin name="cordova-plugin-device" spec="~1.1.1" />
          <plugin name="cordova-plugin-device-motion" spec="~1.2.0" />
          <plugin name="cordova-plugin-device-orientation" spec="~1.0.2" />
          <plugin name="cordova-plugin-dialogs" spec="~1.2.0" />
          <plugin name="cordova-plugin-file" spec="~4.1.1" />
          <plugin name="cordova-plugin-file-transfer" spec="~1.5.0" />
          <plugin name="cordova-plugin-geolocation" spec="~2.1.0" />
          <plugin name="cordova-plugin-globalization" spec="~1.0.3" />
          <plugin name="cordova-plugin-inappbrowser" spec="~1.3.0" />
          <plugin name="cordova-plugin-media" spec="~2.2.0" />
          <plugin name="cordova-plugin-network-information" spec="~1.2.0" />
          <plugin name="cordova-plugin-splashscreen" spec="~3.2.1" />
          <plugin name="cordova-plugin-statusbar" spec="~2.1.2" />
          <plugin name="cordova-plugin-vibration" spec="~2.1.0" />
          <plugin name="cordova-plugin-whitelist" spec="~1.2.1" />
      </widget>
      Thank you!
