I'm trying to create a counter, and the slider control works well when I'm trying to start from 0, but how would I create the counter if I wanted to start from a number other than 0, like from 121 to 618 or something like that?
Thank you
- If your are using the Numbers Effect you have an Value/Offset/Random Max parameter where you can start your number at a specific number.
- If you are using the Timecode Effect, you must set the Time Source to Custom and then, under the Custom category you can change the Starting frame.
- If you are using an expression controller (slider), simply change your value to the desired number and animate it using keyframes.
