2 Replies Latest reply on May 19, 2008 7:19 AM by EvolvedDSM
    Need update function for datagrid selected item
    EvolvedDSM Level 2
      Hello -- I'm using CF+ Flex+ FDS to connect and modify data. I am building a form that info is entered into, and then inserted into my database using a the wizard CFCs to insert records. That data is then displayed in a datagrid with the rest of the data in the db. When I need to update the info, I select the record from the datagrid and it populates my update form fields. However this is as far as I can get. I do not know how to write the update function to take the changed values of the update form and update the db with these values.
      I know the datagrid has an edit feature, however the field I need to update is not going to be a column of this datagrid. So I need to do it via a form where I can assign a value to the field. Currently i am inserting and deleting records using dataServices with an arrayCollection. Any help on an update function would be great, thanks
