After updating to the latest version of LR CC Classic I now have a huge problem. When I export a bunch of photos to Smugmug, LR hangs up after only exporting 13 photos. No error messages. If I try to exit LR I get the pop up that a process is still going on, do I really want to exit. I say yes, but LR is hung. I must use Resource Monitor to kill the LR process. I then start LR up again, and repeat the process until all my photos are exported. This is maddening: 13 photos at a time then kill LR then repeat until finally all the photos are exported.
This has never happened before. It only started after the last LR CC Classic Update.
How can I revert back to the prior version of LR?
Why does Adobe release such big ridden software?
Pasted below are my system details:
Lightroom Classic version: 7.2 [ 1156743 ]
License: Creative Cloud
Language setting: en
Operating system: Windows 7 - Business Edition
Version: 6.1.7601
Application architecture: x64
System architecture: x64
Logical processor count: 12
Processor speed: 3.2 GHz
Built-in memory: 24574.3 MB
Real memory available to Lightroom: 24574.3 MB
Real memory used by Lightroom: 1606.7 MB (6.5%)
Virtual memory used by Lightroom: 1655.3 MB
GDI objects count: 690
USER objects count: 2548
Process handles count: 1450
Memory cache size: 268.7MB
Internal Camera Raw revision: 894
Maximum thread count used by Camera Raw: 5
Camera Raw SIMD optimization: SSE2
Camera Raw virtual memory: 292MB / 12287MB (2%)
Camera Raw real memory: 293MB / 24574MB (1%)
System DPI setting: 96 DPI
Desktop composition enabled: Yes
Displays: 1) 1920x1080, 2) 1680x1050
Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
Graphics Processor Info:
OpenGL: GeForce GTX 780/PCIe/SSE2
Check OpenGL support: Passed
Vendor: NVIDIA Corporation
Version: 3.3.0 NVIDIA 388.13
Renderer: GeForce GTX 780/PCIe/SSE2
LanguageVersion: 3.30 NVIDIA via Cg compiler
Total Video Memory: 3072 MB
Application folder: C:\Program Files\Adobe\Adobe Lightroom Classic CC
Library Path: G:\Just_LR_Catalog\SCYSeals_LR_Catalog-2.lrcat
Settings Folder: C:\Users\OWNER\AppData\Roaming\Adobe\Lightroom
Installed Plugins:
1) AdobeStock
2) Canon Tether Plugin
3) DxO Optics Pro 9
4) DxO Optics Pro 9 Importer
5) DxO OpticsPro 10
6) DxO OpticsPro 10 Importer
7) Export to Photomatix Pro
8) Facebook
9) Flickr
10) HDR Efex Pro
11) HDR Efex Pro 2
12) jf Metadata Viewer
13) Nikon Tether Plugin
14) ON1 Photo RAW 2017
15) ON1 Resize 2017
16) SHARPEN projects professional
17) Show Focus Points
18) SmugMug
Config.lua flags: None
Adapter #1: Vendor : 10de
Device : 1004
Subsystem : 104b196e
Revision : a1
Video Memory : 3013
AudioDeviceIOBlockSize: 1024
AudioDeviceName: Speakers (Realtek High Definition Audio)
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: 10.0x7
Direct2DEnabled: false
GL_ACCUM_ALPHA_BITS: 16
GL_ACCUM_BLUE_BITS: 16
GL_ACCUM_GREEN_BITS: 16
GL_ACCUM_RED_BITS: 16
GL_ALPHA_BITS: 0
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 4
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: GeForce GTX 780/PCIe/SSE2
GL_SHADING_LANGUAGE_VERSION: 4.60 NVIDIA
GL_STENCIL_BITS: 8
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 4.6.0 NVIDIA 388.13
Have you tried resetting Lightroom preferences? Doing so often clears odd behaviour.
https://helpx.adobe.com/lightroom/help/setting-preferences-lightroom.html
I have problem that looks very similar ... tried reset preferences and no resolved.
A new SmugMug plugin v3.1.6.0 downloaded today ... problem seems resolved in my case.
Same issue. SmugMug update freezes at the one third point then I can't cancel the upload and I can't close LR normally. I have to use the task manager. I'm using the latest SmugMug plugin according to the LR plugin manager. LR Classic CC 7.2 upgraded from LR6.
To add to my previous post, I noticed that the plugin will only upload 13 photos, same as the original poster. Interestingly, I had another two photos in the queue to remove from SmugMug. When the plugin froze at 13 uploads this last time, I decided to click on 'Publish' again to see if the two pics to remove would actually execute. It did! And the original process finished AND Lightroom continued to work and close normally. Hmmm...
Tonight I am experiencing the freeze when trying to export photos after developing. I select export and nothing happens. The command line grays out and nothing else will work in Lightroom. I have to kill the program with Task Manager. When opening Lightroom it opens with the same photo with all of the settings, but freezes again as soon as I hit export. I removed the photo and started completely over to the same result. I also updated (although it had just done that last week) and nothing has changed. I hope Adobe is reviewing this issue as it seems to be happening after their latest update.
I was able to resolve the export issue with the help of Adobe. I deleted Lightroom and installed an earlier version. Good luck!
Optimize the catalogue in the preference settings
I have had the same issue with smugmug, nit always the same number of images published before failure, but yes, the publish stops and I get an error message that a folder could not be found (that’s not exact)
now, that’s a folder at the smugmug server, not on my PC. If I attempt later at night (U.S.A. Pacific) then no such issues
this might be an issue at smugmug nit at your computer???
By the way, can an OP in this forum change the title of a posting, perhaps you can change this one to state Publish instead of Export?
