1 Reply Latest reply on May 10, 2008 2:35 PM by clbeech
    How do I make buttons work?
    Lost-in-CS3
      I am taking a college course which includes learning some things about Dreamweaver/Flash, but the text I have is 3 generations behind the current software. I am trying to make a start and stop button...it's not working. I have the symbols created, the start/stop text put there, and the Buttons layer created above my motion guide layer (with the motion guide nested).
      My instructions tell me to go to:
      Windows
      Actions
      Actions Folder (not there in the newer software)
      Movie Control
      Play - double click
      Stop - double click
      At this point I'm supposed to be able to close out of the Actions pane and play/stop the movie using the buttons.
      As I said these instructions are very old - how do I accomplish this in the newer software? I assume there is a simple way and I'm just not seeing it:-)
      Thanks for your help...
        • 1. Re: How do I make buttons work?
          clbeech Level 3
          first you need to determine which programming language you want to use AS2 or AS3 - since the syntax is different to handle mouse event (ie - a click) - then 'today' we usually create a new layer called 'actions' and place code within frames in that layer. so you would select the first frame and then open the actions panel and place your button's code -
          if using AS2:
          play_btn.onPress = function() {
          play();
          stop_btn.onPress = function() {
          stop();
          however if you've decided to use AS3:
          function playMovie(event:MouseEvent) {
          play();
          function stopMovie(event:MouseEvent) {
          stop();
          play_btn.addEventListener(MouseEvent.CLICK, playMovie);
          stop_btn.addEventListener(MouseEvent.CLICK, stopMovie);
          in both cases another thing you need to do is give the buttons 'instance names' - do this by selecting one on the Stage and looking in the properties panel - you will see the box for the instance name - type a name for the button, and then use that name in code when referring to that object. (eg - play_btn, stop_btn)
