Every time when im going to render my project in AAE or Media Encoder it failed on 4th second.
Why?
GPU: NVIDIA GeForce GTS 450
Well, that's not a lot of information you're giving us.
Instead of writing this you should say what you need.
Version: CC 15.0.1
Windows 10 64-bit
RAM 8GB
Latest GPU drivers
Quicktime installed - 7.7.9
Using Magic Bullet Looks by Red-Gaint and Twitch by Video Copilot.
Error while rendering in Media Encoder:
- Encoding Time: 00:02:30
02/24/2018 07:43:37 PM : Encoding Failed
Export Error
Error compiling movie.
Render Error
Render returned error.
Writing with exporter: H.264
Writing to file: \\?\E:\Editing\End of the *** world\Try it.mp4
Writing file type: H264
Around timecode: 00;00;04;01 - 00;00;04;17
Rendering at offset: 4,037 seconds
Component: H.264 of type Exporter
Selector: 9
Error code: -1609629695
I'd change the output file name. Asterisks are not allowed in Windows file names. So try to render it as 'test.mp4' and see if that works. If not, you'll need to provide a link to the comp somewhere so we can check.
Regards,
Wim
Regards,
Wim
It won't work.
Project: https://www.dropbox.com/s/f6fwx180natsimb/Untitled%20Project.aep?dl=0
The obvious thing to do would be to check out what exactly is being rendered at 4 seconds: image, effects, ect...
Transform, Optics Compensation, Exposure, Warp.
Well it failed every time after 4s, when i start render after 00:04:00 it crashes about at 00:07:00-00:08:00.
Can someone help me?
try turning off GPU acceleration for video rendering and effects in the project settings in Ae.
My suggestion is to exercise your troubleshooting skills.
Just back out things until it works, even if the output is useless, you are just trying to understand what's going on. Image you are Bill Murray in Groundhog Day. Keep trying until you get it right.
Shorten your comp to 3 seconds.
Remove effects you don't know.
Remove plug-ins from the comp.
Use stills not video, or use 720p video, make it simpler and simpler.
Keep backing things out until it isn't broken then add things back in until it breaks.
May the force be with you!
Yes, what BartonGarrett256 said. That's how you troubleshoot problems and that's was I was hinting at. Your first clue is the time or times it's crashing at, the problem likely lives somewhere around there. Go to those times and start removing things one at a time. If I were you I wouldn't bother rendering the first 3 minutes & 45 seconds every time.
You might want to monitor your hardware usage while it renders as well. Could be clues there too.
