3 Replies Latest reply on Feb 25, 2018 3:48 AM by D Fosse
    Photoshop on portable SSD?
    AMelendez26
      So, basically I ran out of space on my computer and was wondering if it was possible to install photoshop on a portable SSD to  free up space and spend up loading time?
        • 1. Re: Photoshop on portable SSD?
          I have never done that it may be possible using the Advance installer options.  I use the advance options to keep older version of Photoshop installed.  I do not remember what other options there are in there  I would think it is  possible to  change where it install Photoshop it would be in there. .
          • 2. Re: Photoshop on portable SSD?
            rayek.elfin Level 4
            Sure, that should be no problem. Whether it will speed up loading? Not certain - depends on the USB speed. It will probably load up slower. It's a better idea to free up space by removing data files - source files of work that you've done, and other larger data files.
            Generally it is not a great idea to install your major software on an external drive.
            • 3. Re: Photoshop on portable SSD?
              D Fosse Adobe Community Professional & MVP
              Most of it still ends up on your system drive, under your user account.
              And that's where the junk accumulates, from all your applications. A thorough sweep of your user account can often free up 10 - 60 gigabytes or more. Empty out all app caches (or move them). Bridge alone can be responsible for 20 GB.
              In addition, run disk cleanup to remove all kinds of other leftover system files.
