6 Replies Latest reply on Feb 26, 2018 12:35 AM by kp65128755
    3D Menu Partially Greyed out
    kp65128755
      I am using Photoshop CC (extended) and I have the 3D menu. I can only click on "Get More Content" and "3D Print Utilities". Other than that, everything else is whited out. I searched all over the forum and Youtube, but couldn't find an answer. I have checked Preferences > Using Graphics Processor is checked and in Advanced Settings, Use Graphics Processor to Accelerate Computation is checked.
      Is it because my VRAM is 248 mb? I'm using a macbook pro, is there no work around?
      Here are my specs:
      Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
      Number of Launches: 39
      Operating System: Mac OS 10.12.4
      System architecture: Intel CPU Family:6, Model:23, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
      Physical processor count: 2
      Processor speed: 2400 MHz
      Built-in memory: 4096 MB
      Free memory: 1837 MB
      Memory available to Photoshop: 2841 MB
      Memory used by Photoshop: 70 %
      History Thumbnails: Enabled.
      Touch Bar: Enabled.
      Alias Layers: Disabled.
      Modifier Palette: Disabled.
      Highbeam: Enabled.
      Image tile size: 128K
      Image cache levels: 4
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Main Display
      Display Bounds: top=0, left=0, bottom=800, right=1280
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGLGPUs=1
      NumCLGPUs=1
      NumNativeGPUs=0
      glgpu[0].GLVersion="2.1"
      glgpu[0].IsIntegratedGLGPU=0
      glgpu[0].GLMemoryMB=256
      glgpu[0].GLName="NVIDIA GeForce 320M OpenGL Engine"
      glgpu[0].GLVendor="NVIDIA Corporation"
      glgpu[0].GLVendorID=4318
      glgpu[0].GLRectTextureSize=8192
      glgpu[0].GLRenderer="NVIDIA GeForce 320M OpenGL Engine"
      glgpu[0].GLRendererID=16918042
      glgpu[0].HasGLNPOTSupport=1
      glgpu[0].CanCompileProgramGLSL=1
      glgpu[0].GLFrameBufferOK=1
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
      clgpu[0].CLPlatformVersion="1.2 (Mar  6 2017 20:53:28)"
      clgpu[0].CLDeviceVersion="1.0 "
      clgpu[0].IsIntegratedCLGPU=0
      clgpu[0].CLMemoryMB=256
      clgpu[0].CLName="GeForce 320M"
      clgpu[0].CLVendor="NVIDIA"
      clgpu[0].CLVendorID=16918016
      clgpu[0].CLDriverVersion="10.2.34 310.90.10.05b54"
      clgpu[0].CLBandwidth=2.99005e+09
      clgpu[0].CLCompute=23.3154
      License Type: Subscription
      Serial number: 90970969736351646650
      GUIDBucket:
        bucket: 49
        test: control
      Application folder: /Applications/Adobe Photoshop CC 2017/
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 237.7G, 125.2G free
      Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-ins/
      Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
      Installed components:
         AdbePM.framework   AdbePM   2.5.00.377243   1.578146
         adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
         AdobeACE.framework   AdobeACE   2.20.02.37848   79.579975
         AdobeAGM.framework   AdobeAGM   4.30.87.37848   79.579975
         AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
         AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
         AdobeBIB.framework   AdobeBIB   1.2.03.37848   79.579975
         AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.579975
         AdobeCoolType.framework   AdobeCoolType   5.15.00.37848   79.579975
         AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
         AdobeExtendScript.framework   AdobeExtendScript   4.5.6.5   80.1089815
         AdobeJP2K.framework   AdobeJP2K   1.2.2.38234   79.266006
         AdobeLinguistic.framework      22175
         AdobeMPS.framework   AdobeMPS   5.8.1.37174   79.577269
         AdobeOwl.framework   AdobeOwl   5.2.11
         AdobePDFL.framework   AdobePDFL   15.0.0.36975   79.195992
         AdobePDFSettings.framework   AdobePDFSettings   1.4
         AdobePIP.framework   AdobePIP   7.4.1.60.45263
         AdobeScCore.framework   AdobeScCore   4.5.6.5   80.1089815
         AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.37848   79.579975
         AdobeSVGRE.framework   AdobeSVGRE   6.0   79.579975
         AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
         AdobeXMP.framework   AdobeXMPCore   79.159824   79.159824
         AdobeXMPFiles.framework   AdobeXMPFiles   79.159824   79.159824
         AdobeXMPScript.framework   AdobeXMPScript   79.159824   79.159824
         ahclient.framework   ahclient   2.2.0.1
         AIDE.framework   AIDE   1.5.0.36540   79.574279
         aif.framework   aif   6.0.00.1   1.
         amtlib.framework   amtlib   10.0.0.119
         boost_date_time.framework   boost_date_time   10.0.0.0
         boost_filesystem.framework   boost_filesystem   10.0.0.0
         boost_signals.framework   boost_signals   10.0.0.0
         boost_system.framework   boost_system   10.0.0.0
         boost_threads.framework   boost_threads   10.0.0.0
         Cg.framework   NVIDIA Cg
         CITThreading.framework
         dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
         dvacore.framework   dvacore   10.0.0.0
         dvamarshal.framework   dvamarshal   10.0.0.0
         dvamediatypes.framework   dvamediatypes   10.0.0.0
         dvametadata.framework   dvametadata   10.0.0.0
         dvametadataapi.framework   dvametadataapi   10.0.0.0
         dvametadataUI.framework   dvametadataUI   10.0.0.0
         dvaplayer.framework   dvaplayer   10.0.0.0
         dvatransport.framework   dvatransport   10.0.0.0
         dvaui.framework   dvaui   10.0.0.0
         dvaunittesting.framework   dvaunittesting   10.0.0.0
         dynamiclink.framework   dynamiclink   10.0.0.0
         ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
         ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
         ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
         LogSession.framework   LogSession   7.4.1.60.45263
         manta.framework   manta   2.0.00.1   1.
         mediacoreif.framework   mediacoreif   10.0.0.0
         PlugPlugExternalObject.framework      7.0.0.67
         PlugPlugOwl.framework   PlugPlugOwl   7.0.0.67
         UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
         WRServices.framework
      Required plug-ins:
         3D Studio 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Accented Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Adaptive Wide Angle 18.1.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
         Angled Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Average 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
         Bas Relief 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         BMP 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Camera Raw 9.10.1 (750), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Camera Raw Filter 9.10.1 (750), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Chalk & Charcoal 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Chrome 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Cineon 18.1.1  ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
         Clouds 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Collada DAE 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Color Halftone 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Colored Pencil 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         CompuServe GIF 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Conté Crayon 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Craquelure 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crop and Straighten Photos 18.1.1  Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
         Crop and Straighten Photos Filter 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Crosshatch 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crystallize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Cutout 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Dark Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         De-Interlace 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dicom 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
         Difference Clouds 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Diffuse Glow 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Displace 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dry Brush 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Eazel Acquire 18.1.1  Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
         Entropy 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Export Color Lookup Tables 18.1.1  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
         Extrude 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         FastCore Routines 18.1.1  ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
         Fibers 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Film Grain 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Filter Gallery 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Flash 3D 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Fresco 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glass 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glowing Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Google Earth 4 KMZ 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Graphic Pen 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Halftone Pattern 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         HDRMergeUI 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
         HSB/HSL 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         IFF Format 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         IGES 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Ink Outlines 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         JPEG 2000 18.1.1  Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
         Kurtosis 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Lens Blur 18.1.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
         Lens Correction 18.1.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
         Lens Flare 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Liquify 18.1.1, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
         Matlab Operation 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Maximum 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Mean 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Measurement Core 18.1.1  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
         Median 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Mezzotint 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Minimum 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         MMXCore Routines 18.1.1  ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
         Mosaic Tiles 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Multiprocessor Support 18.1.1  Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
         Neon Glow 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Note Paper 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         NTSC Colors 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
         Ocean Ripple 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         OpenEXR 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Paint Daubs 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Palette Knife 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Patchwork 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Paths to Illustrator 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         PCX 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
         Photocopy 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Photoshop 3D Engine 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
         Photoshop Touch Copyright ©2013-2017 Adobe Systems Incorporated - from the file “PSDX.plugin”
         Picture Package Filter 18.1.1  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Pinch 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pixar 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
         Plaster 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Plastic Wrap 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         PLY 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         PNG 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pointillize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Polar Coordinates 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Portable Bit Map 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
         Poster Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         PRC 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Radial Blur 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Radiance 18.1.1  ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
         Range 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Render Color Lookup Grid 18.1.1  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
         Reticulation 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Ripple 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Rough Pastels 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Save for Web 18.1.1, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
         ScriptingSupport 18.1.1, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
         Shake Reduction 18.1.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
         Shear 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Skewness 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Smart Blur 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Smudge Stick 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Solarize 18.1.1  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
         Spaces 18.1.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
         Spatter 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Spherize 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Sponge 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Sprayed Strokes 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stained Glass 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stamp 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Standard Deviation 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         STL 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Sumi-e 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Summation 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Targa 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Texturizer 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Tiles 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Torn Edges 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Twirl 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         U3D 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Underpainting 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Vanishing Point 18.1.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
         Variance 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
         Virtual Reality Modeling Language | VRML 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Water Paper 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Watercolor 18.1.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Wave 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wavefront|OBJ 18.1.1  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
         Wind 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wireless Bitmap 18.1.1  ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
         ZigZag 18.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
      Optional and third party plug-ins: NONE
      Duplicate and Disabled plug-ins: NONE
      Plug-ins that failed to load: NONE
