9 Replies Latest reply on Mar 1, 2018 1:25 PM by MandyMaude
    Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
    MandyMaude Level 1
      When making any sort of change to any of my images, there is at best a lag, at worst, nothing happens at all. I cannot select pixels. Only half of my filters and actions produce any sort of result. I can copy a layer, but when I do, the layer preview in the layers panel appears blank, even if the copy is successfully made.
      From time to time I can get an action to show up when I move on to making another edit, but that doesn't happen every time.
      I'm on a iMac (Retina 5K,  late 2015) with 1TB Fusion Drive available - running High Sierra version 10.13.3.
      I have deleted all Photoshop preference files, uninstalled the app, reinstalled it and restarted the computer, checked and unchecked "Use Graphics Processor," and "Show Start Workspace When No Documents Are Open" - nothing seems to solve any of the problems.
      I just upgraded to Photoshop CC from Photohshop 6 and am finding it (at least this version) to be absolutely unusable.
        • 1. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
          Use CC 2018 menu help>System Info copy and paste the info here. Some Mac user may be able to see something in there
          • 2. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
            MandyMaude Level 1
            System Info:
            Adobe Photoshop Version: 19.1.1 20180206.r.254 2018/02/06: 1156206  x64
            Number of Launches: 8
            Operating System: Mac OS 10.13.3
            System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
            Physical processor count: 4
            Processor speed: 3200 MHz
            Built-in memory: 16384 MB
            Free memory: 9631 MB
            Memory available to Photoshop: 14274 MB
            Memory used by Photoshop: 70 %
            Alias Layers: Disabled.
            Modifier Palette: Disabled.
            Highbeam: Disabled.
            Touch Bar Property Feedback: Enabled.
            Image tile size: 1024K
            Image cache levels: 4
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Main Display
            High DPI Monitor
            Display Bounds: top=0, left=0, bottom=1440, right=2560
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=1
            NumNativeGPUs=1
            glgpu[0].GLVersion="2.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=2048
            glgpu[0].GLName="AMD Radeon R9 M390 OpenGL Engine"
            glgpu[0].GLVendor="ATI Technologies Inc."
            glgpu[0].GLVendorID=4098
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="AMD Radeon R9 M390 OpenGL Engine"
            glgpu[0].GLRendererID=16915458
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:30:00)"
            clgpu[0].CLDeviceVersion="1.2 "
            clgpu[0].IsIntegratedCLGPU=0
            clgpu[0].CLMemoryMB=2048
            clgpu[0].CLName="AMD Radeon R9 M390 Compute Engine"
            clgpu[0].CLVendor="AMD"
            clgpu[0].CLVendorID=16915456
            clgpu[0].CLDriverVersion="1.2 (Dec 20 2017 17:28:06)"
            clgpu[0].CLBandwidth=1.25342e+11
            clgpu[0].CLCompute=855.868
            nativegpu[0].NativeName="AMD Radeon R9 M390"
            License Type: Subscription
            Serial number: 96040256227058763477
            GUIDBucket:
            Application folder: /Applications/Adobe Photoshop CC 2018/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 951.8G, 829.0G free
            Required Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-ins/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Plug-ins/
            Installed components:
               AdbePM.framework   AdbePM   2.5.00.377243   1.578146
               adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
               AdobeACE.framework   AdobeACE   2.20.02.39705   79.589342
               AdobeAGM.framework   AdobeAGM   4.30.87.39705   79.589342
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
               AdobeBIB.framework   AdobeBIB   1.2.03.39705   79.589342
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.39705   79.589342
               AdobeCoolType.framework   AdobeCoolType   5.17.00.39705   79.589342
               AdobeCrashReporter.framework   AdobeCrashReporter   7.6.0
               AdobeExtendScript.framework   AdobeExtendScript   4.5.8.1   81.1150526
               AdobeJP2K.framework   AdobeJP2K   1.2.2.38423   79.266298
               AdobeLinguistic.framework      22175
               AdobeMPS.framework   AdobeMPS   5.8.1.38423   79.582572
               AdobeOwl.framework   AdobeOwl   5.2.11
               AdobePDFL.framework   AdobePDFL   15.0.0.38423   79.226411
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   7.4.1.109.46827
               AdobeScCore.framework   AdobeScCore   4.5.8.1   81.1150526
               AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.38473   79.582907
               AdobeSVGRE.framework   AdobeSVGRE   6.0   79.588619
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   79.160451   79.160451
               AdobeXMPFiles.framework   AdobeXMPFiles   79.160451   79.160451
               AdobeXMPScript.framework   AdobeXMPScript   79.160451   79.160451
               ahclient.framework   ahclient   3.0.0.6
               AIDE.framework   AIDE   1.5.0.36540   79.574279
               aif.framework   aif   6.0.00.1   1.
               amtlib.framework   amtlib   10.0.0.221
               boost_date_time.framework   boost_date_time   11.1.0.0
               boost_filesystem.framework   boost_filesystem   11.1.0.0
               boost_signals.framework   boost_signals   11.1.0.0
               boost_system.framework   boost_system   11.1.0.0
               boost_threads.framework   boost_threads   11.1.0.0
               Cg.framework   NVIDIA Cg
               CITThreading.framework
               dvaaudiodevice.framework   dvaaudiodevice   11.1.0.0
               dvacore.framework   dvacore   11.1.0.0
               dvamarshal.framework   dvamarshal   11.1.0.0
               dvamediatypes.framework   dvamediatypes   11.1.0.0
               dvametadata.framework   dvametadata   11.1.0.0
               dvametadataapi.framework   dvametadataapi   11.1.0.0
               dvametadataUI.framework   dvametadataUI   11.1.0.0
               dvaplayer.framework   dvaplayer   11.1.0.0
               dvatransport.framework   dvatransport   11.1.0.0
               dvaui.framework   dvaui   11.1.0.0
               dvaunittesting.framework   dvaunittesting   11.1.0.0
               dynamiclink.framework   dynamiclink   11.1.0.0
               ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
               ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
               ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
               k2.framework   k2   1
               LogSession.framework   LogSession   7.4.1.109.46827
               manta.framework   manta   2.0.00.1   1.
               mediacoreif.framework   mediacoreif   11.1.0.0
               PlugPlugExternalObject.framework      8.5.0.87
               PlugPlugOwl.framework   PlugPlugOwl   8.5.0.87
               UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
               WRServices.framework
            Required plug-ins:
               3D Studio 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Accented Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 19.1.1, © 2014-2018 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Average 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “Average.plugin”
               Bas Relief 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               BMP 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Camera Raw 10.2 (894), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 10.2 (894), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Chrome 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Cineon 19.1.1  © 2002-2018 Adobe. All rights reserved. - from the file “Cineon.plugin”
               Clouds 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
               Collada DAE 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Color Halftone 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Colored Pencil 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               CompuServe GIF 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Conté Crayon 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Craquelure 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 19.1.1  © 2003-2018 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Crosshatch 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Crystallize 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Cutout 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Dark Strokes 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               De-Interlace 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Dicom 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “dicom.plugin”
               Difference Clouds 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
               Diffuse Glow 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Displace 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Dry Brush 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Eazel Acquire 19.1.1  © 2007-2018 Adobe. All rights reserved. - from the file “EazelAcquire.plugin”
               Entropy 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Export Color Lookup Tables 19.1.1  © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
               Extrude 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               FastCore Routines 19.1.1  © 1990-2018 Adobe. All rights reserved. - from the file “FastCore.plugin”
               Fibers 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Film Grain 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Filter Gallery 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Flash 3D 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Fresco 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Glass 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Glowing Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Graphic Pen 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Halftone Pattern 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Halide Bottlenecks 19.1.1  © 2018 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin”
               HDRMergeUI 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin”
               HSB/HSL 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               IFF Format 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               IGES 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Ink Outlines 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               JPEG 2000 19.1.1  © 2001-2018 Adobe. All rights reserved. - from the file “JPEG2000.plugin”
               Kurtosis 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Lens Blur 19.1.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Blur.plugin”
               Lens Correction 19.1.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Correct.plugin”
               Lens Flare 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Liquify 19.1.1, © 2001-2018 Adobe. All rights reserved. - from the file “Liquify.plugin”
               Matlab Operation 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
               Maximum 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Mean 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Measurement Core 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “MeasurementCore.plugin”
               Median 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Mezzotint 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Minimum 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               MMXCore Routines 19.1.1  © 1990-2018 Adobe. All rights reserved. - from the file “MMXCore.plugin”
               Mosaic Tiles 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Multiprocessor Support 19.1.1  © 1990-2018 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin”
               Neon Glow 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Note Paper 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               NTSC Colors 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “NTSC Colors.plugin”
               Ocean Ripple 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               OpenEXR 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Paint Daubs 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Palette Knife 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Patchwork 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Paths to Illustrator 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               PCX 19.1.1  © 1989-2018 Adobe. All rights reserved. - from the file “PCX.plugin”
               Photocopy 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “Photoshop3DEngine.plugin”
               Photoshop Touch ©2013-2018 Adobe. All rights reserved. - from the file “PSDX.plugin”
               Picture Package Filter 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
               Pinch 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Pixar 19.1.1  © 1989-2018 Adobe. All rights reserved. - from the file “Pixar.plugin”
               Plaster 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Plastic Wrap 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               PLY 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Pointillize 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 19.1.1  © 1989-2018 Adobe. All rights reserved. - from the file “PBM.plugin”
               Poster Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               PRC 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Radial Blur 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Radiance 19.1.1  © 2003-2018 Adobe. All rights reserved. - from the file “Radiance.plugin”
               Range 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Render Color Lookup Grid 19.1.1  © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
               Reticulation 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Ripple 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Rough Pastels 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Save for Web 19.1.1, © 1999-2018 Adobe. All rights reserved. - from the file “Save for Web.plugin”
               ScriptingSupport 19.1.1, © 2002-2018 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin”
               Shake Reduction 19.1.1, © 2014-2018 Adobe. All rights reserved. - from the file “Shake Reduction.plugin”
               Shear 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Skewness 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Smart Blur 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Smudge Stick 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Solarize 19.1.1  © 1993-2018 Adobe. All rights reserved. - from the file “Solarize.plugin”
               Spaces 19.1.1, © 2015-2018 Adobe. All rights reserved. - from the file “Spaces.plugin”
               Spatter 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Spherize 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Sponge 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Sprayed Strokes 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Stained Glass 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Stamp 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Standard Deviation 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               STL 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Sumi-e 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Summation 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Targa 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Texturizer 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Tiles 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Torn Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Twirl 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               U3D 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Underpainting 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Vanishing Point 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “VanishingPoint.plugin”
               Variance 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
               Virtual Reality Modeling Language | VRML 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Water Paper 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Watercolor 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
               Wave 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 19.1.1  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
               Wind 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 19.1.1  © 1989-2018 Adobe. All rights reserved. - from the file “WBMP.plugin”
               ZigZag 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins: NONE
            Duplicate and Disabled plug-ins: NONE
            Plug-ins that failed to load: NONE
            Extensions:
               com.adobe.Butler.backend  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
               com.adobe.inapp.purchase  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html ”
               New Document  2.1.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_1_1_004/fnft.html”
               Libraries  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
               Start  2.1.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_1_1_076/index.html”
               Noun Project  1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.thenounproject.nounPanel/index.html”
               Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
               Export As  3.1.2 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
            Installed TWAIN devices: NONE
            • 4. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
              I'm not a mac user I do not see anything bad offhand in there.   Make sure you have installed all of Apples updates for your model mac.  Apple seems to control what devices drivers allowed to be installed on mac machines.  The Problem may be related to your mac model and osx version you using.  Hopefully someone with good Mac knowledge can help you.
              • 5. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
                gener7 Adobe Community Professional & MVP
                I run that very version on a 2012 Macbook Pro.10.13.3 and your rig is much better than that.
                First thing that comes to mind are multiple monitors. Are you using those?
                As a troubleshooting step, disable the GPU under Photoshop > Preferences > Performance  and see if things improve.
                • 6. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
                  MandyMaude Level 1
                  Thanks for taking a look! I just ran the latest OS update a couple days ago, so I'm sure I'm up to date.
                  • 7. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
                    MandyMaude Level 1
                    It's such a mystery! Not hooked up to any external monitors. I have quite a bit of RAM/memory as my computer is virtually new and has few programs other than the Adobe Suite even installed. I've tried closing all other programs while working. I have also already tried disabling the GPU - doesn't seem to change anything. Yesterday after some experimenting, I realized I can (sometimes) see my work if I add a new layer, then click into that new layer. As soon as I click the new layer the last edit I made appears. It's a temporary (and frustrating) workaround, but obviously, unacceptable for the long-term.
                    • 8. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
                      I honestly do not know enough about the 5k at this point to give you a useful answer, so let's try installing an earlier version (part of your membership) and see if it works. Let me know if that helps. Try the latest CC 2017 and move downward of that version does not work.
                      So from the Creative Cloud Desktop App:
                      • 9. Re: Photoshop CC 2018 9.1.1: Image changes not appearing on screen or in layers panel
                        MandyMaude Level 1
                        Going back to 18.0 worked! Thanks for that - guess I'll wait it out on the old version until the next update... :-)
