• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop CC Brushes and Pencils not working
Community Beginner ,
Feb 28, 2018 Feb 28, 2018
I was sketching some artwork in Photoshop CC on my Wacom art tablet.  The battery was running low but I thought there was just enough battery to make some quick changes to my sketch right before charging time.  Unfortunately, midway through making changes and constantly saving the project, the art tablet shut down from a low and empty battery.  I put it on charge and turned it back on to make sure nothing was damaged.  The tablet as a whole is fine, but Photoshop seems to have lost the texture of the pencil used and also does not match the texture of the grunge paper effect that I have set as the main layer.  All of my brushes have lost texture and only show up in small increments as I drag the Wacom pencil around.  I tried changing the texture, pattern, and brush spacing preferences for several of the drawing tools but the settings may have been corrupted due to the crash.  Any ideas on how to get Photoshop back to normal and still be able to draw with the same pencil and textures?
Views
3.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 28, 2018 Feb 28, 2018
check your brush settings in Photoshop - spacing would cause the dots to show up, otherewise I would shut down the whole system and restart. Chances are your tablet is only sending intermittent pressure information to the computer since you had an interruption in service.
Votes
Translate
Translate
Adobe
Also, is there a way to save Photoshop and restore it so that this is fixed, while also keeping the projects I have saved and worked on prior to the incident?
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Update.  I was able to fix it just now.  In my case, something was wrong with the photoshop preferences and it couldn't be fixed with the program open.  I first tested to see if my pen and Wacom was the issue, but the pen was able to draw normally on small sketch programs.  Photoshop would only pick up the pencil properly if I held the pen with a sideways slant.  The fix for me was manually deleting the Adobe Photoshop Prefs.psp file and then reopening photoshop.  Thank you for pointing me in the right direction towards fixing the bug!
Votes
Translate
Translate
Report
Report
Guest
Have you tried reseting the brush and pencil setting?
Votes
Translate
Translate
Report
Report
LATEST
Yes, but something was wrong with the preferences in photoshop in general.  I was able to fix it just a few minutes ago though.
Votes
Translate
Translate
Report
Report
