• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Word Document Formatting Issues Once Imported into RoboHelp
Explorer ,
Feb 28, 2018 Feb 28, 2018
I'm using RoboHelp 2015 and sometimes, a document will look completely fine in Word but for some reason, it looks different in RoboHelp.
Here is an example of what this looks like. This is a screenshot of the top of a Word document:
This is what it looks like in RoboHelp (not in the project itself, but once I view the Output and choose a browser:
Here's a closeup of the bullet points:
I also noticed a stray bullet point that appeared that wasn't showing up in Word, but I fixed it by reformatting the Word doc. I'm not sure how to fix the issue with the bullet points though. Do I need to save the Word document as a PDF and then try uploading that?
Views
409
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Linked Word document or imported?
Back in the morning to see your answer. Night night! (I'm in the UK)
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 01, 2018 Mar 01, 2018
Imported Word doc.
Votes
Translate
Translate
Report
Report
Community Expert ,
In one topic with the problem, try the icon below. Don't save if it doesn't help but it might. If not, then as Jeff has pointed out it could be indentation of the second level. Always causes fun. .
Also see what effect a different CSS has. It might not be the CSS that you want but the change might tell us something.
See www.grainge.org for free RoboHelp and Authoring information.
@petergrainge
Votes
Translate
Translate
Report
Report
Community Expert ,
Looking at your Word doc, it appears that you're using 2 different types of bullet point symbols (looks like the larger ones in the second section are getting translated correctly into RH; the top ones clearly aren't). I'd first check the Word style you have applied & then look at the Conversion Settings to see how it's being translated into RH.
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks Jeff! I clicked on the topic with the wonky formatting, then Settings.
I then clicked Edit to "edit conversion settings for Word document".
It looks like I have the options to:
  • Automap Paragraph Styles
  • Automap Character Styles
  • Automap Table Styles
I also have the following options:
Maybe I'll test these out using a test project.
Votes
Translate
Translate
Report
Report
Community Expert ,
What's the Word doc look like for that first section of bullets? I bet it's using a different style than the second part.
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 03, 2018 Mar 03, 2018
LATEST
Mapping of bullets is can be tricky. I have covered one workaround in Importing using RoboHelp under Edit the Word Conversion Settings. However, first I would try the icon I mentioned earlier.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
