I am trying to decrypt multiple pdf files and save them with the same name in a different location. Just to test, i used 2 files. I also created an action using the action wizard . I find that one of the document was processed successfully while the other did not process and i got the error - Unterminated string.
Please note that these PDF files were generated from other systems/applications and i am not using any custom script. I am just using the action wizard.
Is there a workaround or a solution for this?
Raja
Duplicate thread.
Already answered here: Unable to decrypt multiple pdfs (all of them have the same password) - Action Wizard
Are you using a script? If so, post the code you're using.
I am not using any script. Just the action wizard.
Weird... Did you use a quotations-mark in the password field, or something like that?
Nope. The password does not have quotation marks or spl characters in it. In fact, i am able to remove the password security for the particular document manually and save it but unable to do it via the wizard :S
- RB
Duplicate thread.
