2 Replies Latest reply on Jun 8, 2017 1:21 PM by rezun8
    Flash and PHP
    Ryan Padyachie
      Hi There
      I was wondering if somebody could help me out.
      I am a designer, and I have recently designed
      my website entirely in flash.
      I have downloaded a tutorial in which
      I followed all instrutions to create a form in flash
      which connects to a php script.
      Now I have uploaded this php file to the server
      with all my other files,
      however, i know there is some other step like adding a mysql database.
      I know that me free server which is lolhosting does support the use of php,
      Now I dont know how to link my php file to this mysql,
      Can somebody please explain to me how this can be done, or even I have
      my straight.
      Ryan
      South Africa
        • 1. Re: Flash and PHP
          Level 7
          If you have MySQL you will have to set up a database and user, either your
          host can do that, or you will have a control panel where you can do it
          yourself. Just depends on the host. Once you have that, you can make a
          connection to your db using PHP with something like this:
          $connection = mysql_connect("localhost", "user", "password");
          mysql_select_db("databaseName", $connection);
          And then you can query the db with:
          $result = mysql_query("SELECT * FROM table", $connection);
          Dave -
          • 2. Re: Flash and PHP
            rezun8 Level 4
            Ryan , what kind of information are you passing betwen Flash & PHP? if its a simple contact form you may not need a MySQL DB at all. If your wanting to store info then yes you prob will need a DB.
